LJ stub axles?
9 replies to this topic
#1 _0ldey_
_0ldey_
Posted 14 May 2020 - 07:13 PM
A few years ago, I bought a HR disc brake front end. Have just around to rebuilding and the brakes appear to be LJ. The stub axles have been completely smoothed so have no part numbers, but have larger thread on end, are definitely 9 degree KPI and the washer keyway is at 12 o’clock. Hoping someone more knowledgeable may be able to shed some light as am going to advertise them, but want to ensure I am accurate.
#2 limo
limo
  • 2,672 posts
Posted 15 May 2020 - 07:39 PM
The calipers are same but stubb axles different. Due to different steering. Rack and pinion LJ and steering box HR. Some thing to do with steering arm fitment
#3 S pack
  • 15,538 posts
Posted 16 May 2020 - 07:44 AM
I'm pretty sure HR disc calipers are not the same as LC, LJ or HK,T,G either.
#4 claysummers
claysummers
  • 3,325 posts
  • Name:Clay
Posted 16 May 2020 - 01:11 PM
Mount holes in the upright are the same is what he means I t think. The calipers s nd discs are interchangeable as s set with Torana giving a wider offset for more back space.
Sounds like comparing the steering arm mounting holes is a way yo compare. Not sure I can trust myself to measure kpi within 2 deg. Maybe with a disc rotor fitted and measure offsets to ball joint holes top and bottom then high school trig.
#5 S pack
  • 15,538 posts
Posted 16 May 2020 - 01:15 PM
Agree the caliper mounting hole spacing dimensions are the same but that is probably all.
#6 _0ldey_
_0ldey_
Posted 16 May 2020 - 07:20 PM
Thanks folks, fitted them all up and with max number of camber spacers, still have positive camber so are 9 degrees KPI. The front end also had Torana calipers and rotors so am going to go with LJ.
#7 claysummers
claysummers
  • 3,325 posts
  • Name:Clay
Posted 16 May 2020 - 07:44 PM
How you solving camber issue Oldey?
#8 claysummers
claysummers
  • 3,325 posts
  • Name:Clay
Posted 16 May 2020 - 08:19 PM
#9 _0ldey_
_0ldey_
Posted 17 May 2020 - 06:56 PM
Clay, can’t resolve camber issue so will need to find some HR stub axles.
Edited by 0ldey, 17 May 2020 - 06:57 PM.
#10 claysummers
claysummers
  • 3,325 posts
  • Name:Clay
Posted 17 May 2020 - 07:41 PM
