6 cylinder starters
4 replies to this topic
#1 limo
limo
  • 2,673 posts
Posted 18 May 2020 - 09:05 PM
Is the starter motor on the Holden 4 cylinder same as the 6? They should bolt on as can use 4 cylinder gearbox behind 6. I've got couple 4 cylinder Commodores in paddock and some one asked me for a starter for a 202. Just as easy to take one off or go searching in sheds
#2 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 20 May 2020 - 07:37 AM
Pretty sure the 4 cyl starter is slightly smaller than the 6 , it should bolt onto a six but might be a bit lower on output than the six cyl starter , did try a six starter on the 4 once and it would not fit , was a tad too long from memory , will try to get more info can't remember the exact differences.
Edited by EunUCh, 20 May 2020 - 07:38 AM.
#3 LHSL
LHSL
  • 995 posts
  • Name:Phillip
Posted 20 May 2020 - 08:45 AM
Whats the part number on the 4 pot can check off that.
#4 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 21 May 2020 - 07:23 AM
The 4 banger starter is quite a bit shorter and not as fat as the one off the six , the small one might struggle to turn over the six ?
Attached File  20200520_173831.jpg   319.46K   2 downloads
#5 Com_VC
Com_VC
  • 411 posts
Posted 23 May 2020 - 03:08 PM
Wonder how it compares in size to the modern Bosch high torque replacement.  Should chuck a ruler in there to compare measurments.
