LC CONSOLE
42 replies to this topic
#1 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 25 May 2020 - 11:03 AM
G'DAY ALL
TO DO WITH  the CF cars with the all aussie did the early one's have the opel centre console
cheers  bat :huh:
#2 Indy Orange
Indy Orange
  • 2,850 posts
  • Name:Paul
Posted 25 May 2020 - 12:06 PM
The LC console sits to the side slightly to accommodate the M20 Opel Gearbox ,I think by the time the later M20 Aussie one was used in the LCGTR it would have been the LJ type Console .Someone with more knowledge about that could confirm.
#3 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 25 May 2020 - 06:06 PM
Don't forget, by lj type, Paul means lj 4 speed excluding xu1. As the xu1 has the shift patern plate.
#4 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 25 May 2020 - 06:13 PM
Also, I'm pretty sure that it was discussed in the Sally report, the holes in the Opel console are in a different position to the holes in the Aussie console, so if you take acurate measurements, Marty may be able to verify what sort originally came in your car, which would be great information to have. Gary.
#5 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,891 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 26 May 2020 - 02:57 AM
If its got the thin vinyl covering over it its lc..ljs
dont have that..thats all i know haha
#6 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 26 May 2020 - 09:53 AM
well boys
there are 2 that i know of that have all aussie with an opel console
a couple of years back i read a post on here about the CF gtr that there is only 1 knowen opel cf colour is indi orange
just trying to get more info on the subject
cheers  bat
#7 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 26 May 2020 - 06:17 PM
Late lc are plastic aswell & no vinyl covering. Opel style is vinyl.
well boys
cheers  bat
The best way to be sure, is by measurements only, takes away the assumption & gives the facts !
#8 Indy Orange
Indy Orange
  • 2,850 posts
  • Name:Paul
Posted 26 May 2020 - 07:50 PM
LC Opel console.Vinyl covered plastic.LJ console is quite different ,texture and not covered.
#9 Dr Terry
Dr Terry
  • 3,276 posts
Posted 27 May 2020 - 08:00 AM
The "LJ" style console appeared in production around July 71 to allow for the intro of both the M20 Aussie 4-sp & the new 4-sp fitted to the 1600 OHC engine which was released around the same time.
The easiest way to tell the difference apart from the vinyl covering is that the hole is larger & the boot mount holes centres are further apart. The part catalogue specifies either 4 7/8 inch or 6-inch for the later one.
The XU1 console has the same part number & the shift pattern label is listed as a separate part.
Dr Terry
#10 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 27 May 2020 - 11:20 AM
i know the difference between the two consoles
is it possible that they used the opel console with the aussie
what changes were made to the body to fit the m20 aussie
cheers  bat ^_^
#11 S pack
  • 15,541 posts
Posted 27 May 2020 - 12:16 PM
cheers  bat ^_^
Not likely. No modifications were required to the LC body to fit the Aussie M20 transmission.
#12 _haines_
_haines_
Posted 27 May 2020 - 07:19 PM
unreal
#13 Indy Orange
Indy Orange
  • 2,850 posts
  • Name:Paul
Posted 27 May 2020 - 11:24 PM
Oh it's real alright!
#14 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,291 posts
  • Car:ɐuɐɹoʇ
Posted 28 May 2020 - 09:28 AM
Isn't the hole for the reverse switch wire in a different place? I think that this has been identified before.
Bazza
#15 u1 71
u1 71
  • 467 posts
  • Name:peter
  • Car:torana
Posted 28 May 2020 - 11:07 AM
I have a vinyl covered console to suit the Aussie m20 box
#16 crabba67
crabba67
  • 903 posts
  • Name:anthony
Posted 28 May 2020 - 11:17 AM
First photo LC with a opel 4 speed reverse switch wire hole from 9/69 to 8/71
Second photo with M20 aussie 4 speed reverse switch wire hole 9/71 to the end
#17 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 28 May 2020 - 11:23 AM
well i think it is likely
not trying to cause a shit storm but as i have stated there are 2 cars that i know of
those 2 as far as the owners know they are original with the right dates on the gear box
trying to find information on these cars is near on impossible as there doesn't seem to be alot of info out there
so instead of making silly comments show me why it's not possible
hope for some info   bat
#18 meanmachine72
meanmachine72
  • 2,006 posts
  • Name:Jono
Posted 28 May 2020 - 02:50 PM
how about you post pics of those 2 cars mate?.. prove to us they are what you say they are
#19 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 28 May 2020 - 06:03 PM
I'll grab the popcorn !
#20 Ice
  • 15,125 posts
Posted 28 May 2020 - 06:39 PM
Grab a six pack while ya there
#21 _haines_
_haines_
Posted 28 May 2020 - 07:12 PM
Hi there
Here is the real info on the opel gearbox changes
Hope you can read it
The letter has a date etc
yes the hole in the tunnel is in a different location due to the reverse switch in different location on the m20/ m21 gearbox
Tailshaft is different  length and colour of the shaft
speedo cable different
spacers under the cross member is different
shifter is different
gearstick is different on Opel non depress on the ball
etc
if people want to speak about the gearbox changes and not guess about stuff  I am more than happy to help
enjoy the read
#22 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 28 May 2020 - 07:22 PM
still comming with the silly comments
why is it so stupid holden have done it on plenty of occassions by useing left over parts
so why not on the CF one of the cars is mine
instead of making stupid comments prove to me that it didden't happen
i'm new with these cars don't know a lot but trying to learn
some of you's say facebook blokes are a joke maybe some of you's need to look in a mirra
BAT
#23 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 28 May 2020 - 07:27 PM
yes read that letter my understanding it refers to L6 cars not the gtr
#24 crabba67
crabba67
  • 903 posts
  • Name:anthony
Posted 28 May 2020 - 07:45 PM
Hi there
etc
enjoy the read
100% correct at Adelaide it all started at chassis number ALC35###A.
Albert Bat53 read the service letter dated 16 August 1971........L6 is for all six cylinder engine eg: 173S CF.
#25 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 28 May 2020 - 07:57 PM
you are all saying that the reverse wire hole is further back didn't know that (check my build thread post 7)
tail shaft paint colour redoxide
5mm spaces under gearbox x member
gearbox is a smooth case cast date B18 1
