LC CONSOLE
42 replies to this topic
#26 sibhs
sibhs
  • 2,703 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 28 May 2020 - 08:42 PM
Hey Albert, If the car is unmolested, has the reverse switch all aussie position and has the opal centre-console mounting holes that's how you tell if the car is what you think.
Marty
#27 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 28 May 2020 - 09:45 PM
that is what it is marty
what you stated
it got out of hand by a couple of kids because they can't go to the playground
#28 S pack
  • 15,538 posts
Posted 29 May 2020 - 07:45 AM
well i think it is likely
not trying to cause a shit storm but as i have stated there are 2 cars that i know of
those 2 as far as the owners know they are original with the right dates on the gear box
trying to find information on these cars is near on impossible as there doesn't seem to be alot of info out there
so instead of making silly comments show me why it's not possible
hope for some info   bat
LC & LJ Aussie M20 gearshift rubber boot and console. As you can see, the increased physical size of the boot and the more centralised gear stick on the Aussie M20 required a larger aperture in the console to prevent fouling.
#29 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 29 May 2020 - 10:00 AM
i understand what your saying Dave
my car being a CF has an all aussie m20 with an opel console
all the holes in the floor indicate it as such
no holes have been patched and redrilled
so my original question  was, did some of the CF cars come out with this combo
cheers  bat
#30 _LONA-CK_
_LONA-CK_
Posted 30 May 2020 - 11:57 AM
Hi bat (Albert)
When you took out the console did the hole for the shifter still look original, I have seen them use old original stock on the change over cars but that had made the hole a little bigger.
As to the wire hole for the reverse if you look at your build thread post 7 of the pic with your car on its side you will see you have the right hole there for a CF engine prefix built 71, before you replaced the floor pan that is,,, then if you look at the 2 pics the crab man posted you will then see the difference.
Remember the 3 screws that hold the console to the body are all in the same spot, its the holes that hold the rubber boot retainer that are different
Cheers gong
#31 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 30 May 2020 - 04:23 PM
gong check my build thread you will see that the only part of the floor pan i replaced is the bit under the drivers foot and a couple of patches on the rear floor
what makes you think that i have replaced the floor pan !!
don't know what the original hole looks like
i will put a photo of mine
cheers  bat
#32 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 30 May 2020 - 04:31 PM
Don’t know what the original looks like
#33 S pack
  • 15,538 posts
Posted 30 May 2020 - 06:51 PM
Well it looks like they did modify some Opel consoles, as John has indicated, to work with the Aussie M20.
Found these pics in an old thread about consoles.
This pic is an unmodified console.
Attached File  LC console suit Opel.jpg   54.15K   1 downloads
This pic the console looks to have been modified the same as Alberts.
Attached File  LC console suit Aussie M20.jpg   56.2K   1 downloads
#34 S pack
  • 15,538 posts
Posted 31 May 2020 - 08:02 AM
Found this really good pic of a std LC console gearshift cutout to suit the Opel shifter and rubber boot.
Attached File  LC GTR Opel console 05.jpg   196.21K   0 downloads
#35 _LONA-CK_
_LONA-CK_
Posted 31 May 2020 - 09:09 AM
Bat sorry man my wrong, I was thinking you replaced passengers side because in post 7 page 1 of your build thread the hole is clearly there, then done to post 25 page 1 were you have painted floor red hole is gone,, please remember my eyes are getting old now.
That's it Dave...
Cheers gong
#36 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 31 May 2020 - 11:24 AM
no worries gong
i see what you mean in post 25 , i put tap over the hole when i painted
thanks to every one who pitched in to verify what i have
if anyone would like to check it give me a call or pm
cheers  bat
#37 sibhs
sibhs
  • 2,703 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 31 May 2020 - 08:50 PM
Can someone check an opal console and an aussie console that the mounting holes to the tunnel are the same distances apart ( 3 holes).  My tunnel is opal but when I put an LJ console on, the holes are not usable. Holes look original with counter-sink look about them.
John has mentioned above they're the same but I need confirmation for my build.
Marty
#38 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 31 May 2020 - 08:52 PM
Does anyone have any measurements for the location of the m20 reverse wire hole?
#39 sibhs
sibhs
  • 2,703 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 31 May 2020 - 08:53 PM
I need this too.
#40 crabba67
crabba67
  • 903 posts
  • Name:anthony
Posted 31 May 2020 - 09:22 PM
All Opel consoles are the same a factory photo 69 gtr.
#41 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 01 June 2020 - 11:18 AM
my car is in northam i'll get the mesurment when i go up in a couple of weeks
cheers  bat
#42 rodomo
  • 17,999 posts
Posted 03 June 2020 - 10:11 PM
  • Attached File  Pan3.JPG   208.17K   9 downloads
#43 Lc69
Lc69
  • 351 posts
  • Name:Tony
  • Car:1969 LC
Posted 04 June 2020 - 11:50 PM
Awsome, thank you.
I would have guessed further back if I hadn’t seen this.
I have an empty tunnel at the moment, so it will be easy to do this from underneath using these measurements.
Once it’s all done I will try and take some pics for future reference.
