Heater Fan Curly Yellow Resistance Wire
10 replies to this topic
#1 _mickyb!_
_mickyb!_
Posted 29 May 2020 - 09:32 PM
Does anyone know what resistor (ohms and watts) can be used to replace the curly yellow resistance wire for the heater fan motor so I have low and high fan speed ?
Pretty sure the orange wire allows full voltage for high fan speed and the yellow resistance wire drops the voltage down for low fan motor speed but not sure what the equivalent resistor value would be. Anyone know ? Thanks!
#2 ben23
ben23
  • 236 posts
  • Name:Ben
  • Car:'77 LX 2850 sedan
Posted 29 May 2020 - 09:45 PM
About 1.5 - 2 ohms
#3 rodomo
  • 17,999 posts
Posted 29 May 2020 - 09:48 PM
I used ballast resistors on my old FJ40 Landcruiser
#4 _mickyb!_
_mickyb!_
Posted 29 May 2020 - 11:01 PM
Great idea to use a ballast resistor which is about 1.6 ohms. Should do the trick nicely, thanks!
#5 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 30 May 2020 - 09:54 AM
So do the early LH's that are fitted with the Betts motor have a resistor mounted somewhere else?
Attached File  $_5n7.jpg   52.41K   7 downloads
#6 hanra
  • 10,832 posts
Posted 30 May 2020 - 10:03 AM
The yellow wire is nichrome. It’s resistive. So the yellow wire in that example may still be ample to reduce the speed for the type of motor/armature/windings etc.
#7 ben23
ben23
  • 236 posts
  • Name:Ben
Posted 30 May 2020 - 10:08 AM
I think the Betts motors are a proper 2 speed motor.
#8 rodomo
  • 17,999 posts
Posted 30 May 2020 - 10:41 PM
Long time ago and also Toyota but I seem to remember I had 2 in series?...……...Might be wrong? Cheap enough to buy though.
#9 _mickyb!_
_mickyb!_
Posted 31 May 2020 - 07:44 PM
Installed a 1.6 ohm ballast resistor today and it worked a treat :spoton:
#10 HNSGEQ
HNSGEQ
  • 41 posts
  • Name:George Hatzi
  • Car:LX Torana
Posted 11 September 2020 - 07:11 AM
Hi All,
Is anyone aware where I could buy some of the resistor wire for my LX heater? It's perished and want to keep the original look.
Or, would anyone know whether replacing my existing LX heater motor with an LH Betts heater motor will simply plug into my existing LX wiring and provide 2 speed fan control off the LX switch?
Thanks all!!
#11 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 11 September 2020 - 12:13 PM
I just had a quick google, and there is plenty of Nichrome resistor wire around, but none of it is insulated.
