Steering Rack Rubber
13 replies to this topic
#1 arrimar
arrimar
  • 3,121 posts
Posted 30 May 2020 - 04:33 PM
Has anyone had any experience, positive or negative, with Rare Spares Rubber Steering Rack Mounts?
https://www.rarespar...h-lx-uc-exc-a9x
#2 Cook
Cook
  • 1,502 posts
Posted 31 May 2020 - 09:24 AM
Hi arrimar.  I can't recall where I got mine but they are not entirely round, which the Rares once seem to be.  The top is flat so that they sit snug and don't foul on the top. Here's a pic.  Cheers Ron
#3 Cook
Cook
  • 1,502 posts
Posted 31 May 2020 - 09:27 AM
I think mine might be Whiteline.  Cheers Ron
#4 arrimar
arrimar
  • 3,121 posts
Posted 31 May 2020 - 12:04 PM
Yes the shape was one concern, durability the other.
#5 arrimar
arrimar
  • 3,121 posts
Posted 31 May 2020 - 02:16 PM
So not having the flat section appears ok looking at this old rack I have.
I'll give the Rares ones a go.
#6 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 31 May 2020 - 07:22 PM
If those bushes are anything like the Rack Boots I got off Rare Spares (Kelpro) for my LX, they'll be garbage.
I have i think Super Pro in my rack, no troubles.
FYI the Rack Boots from ToranaRPA are fantastic, exactly like the originals and perfect fit. If they do the bushes and you're after original style, I'd check to see if they have them.
#7 arrimar
arrimar
  • 3,121 posts
Posted 31 May 2020 - 08:00 PM
I ordered the boots from mick earlier today. Half the price of Rares too.
#8 TORLX8
TORLX8
  • 586 posts
  • Name:Campbell
Posted 31 May 2020 - 10:53 PM
I purchased some Rares steering rack mounts to replace these Nolathane ones I pulled out, and they are totally wrong.
Not only do they not have the flat side, they are not even close to the correct size. Inside or outside diameter.
I took them back and purchased Whiteline ones as above. Perfect.bf197bf7d11cea7b49dcb5bf186f2337.jpg
Sent from my Moto G (5) using Tapatalk
#9 arrimar
arrimar
  • 3,121 posts
Posted 01 June 2020 - 06:34 PM
I ordered a set of those Rares mounting bushes too. I hope reusing the steel tube will sort out the inner diameter.
#10 mick_in_oz
mick_in_oz
  • 666 posts
  • Car:LX Hatchback
Posted 01 June 2020 - 09:46 PM
They won't be, that Red Bush requires use of the steel insert tube.
#11 arrimar
arrimar
  • 3,121 posts
Posted 03 June 2020 - 04:38 PM
Parts arrived. I'm still hopeful that with compression they'll fit snug.
The stack height looks good.Attached File  Resized_20200603_151516.jpeg   188.54K   4 downloads
The original steel tube matches the inner diameter.
Attached File  20200603_151526.jpeg   189.56K   4 downloads
The nut goes on easy and with some compression I hope it'll fill out nicely.
Attached File  Resized_20200603_152112.jpeg   112.16K   4 downloads
I think the aftermarket ones use a narrower tube.
#12 ReplicarSLR
ReplicarSLR
  • 517 posts
  • Car:Not anymore unfortunately
Posted 03 June 2020 - 05:25 PM
They don’t look right at all they should have a flat part and also a step in them to locate properly in the rack and a crush tube that you use with your existing bolts nuts and large washers. Whiteline part number W11166 is what they should look like
#13 arrimar
arrimar
  • 3,121 posts
Posted 03 June 2020 - 05:59 PM
The original crush tube is reused.
Tube is wider than the aftermarket ones with a plastic insert that grips the bolt. Pretty smart.
The original rubbers I pulled out don't have a flat spot. Yes they are deformed from being squashed.
I know what aftermarket ones look like. Doesn't mean they were direct copies of the genuine part.
I'll bolt it all up and see what happens when they're under pressure.
If they're shite I'll let Rare Spares know.
Attached File  Resized_20200603_151714.jpeg   124.81K   4 downloads
#14 arrimar
arrimar
  • 3,121 posts
Posted 11 July 2020 - 06:51 PM
When fitted and compressed the rares rubbers look just like the ones I pulled out. Now to see how long they last.
