Turbo 350 identification
18 replies to this topic
#1 rexy
rexy
  • 3,588 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 31 May 2020 - 05:59 PM
Hi everyone.
I have a turbo 350 that allegedly came out of a WB statesman.
Attached File  4EB25A1B-3E5D-4985-A535-2BBDAF8C1D15.jpeg   132.09K   8 downloads
Attached File  59530E95-DADB-4408-A909-7A8EC4C42972.jpeg   153.41K   9 downloads
Attached File  7122F09D-0441-4E6B-BEA6-43855EA235D3.jpeg   149.02K   8 downloads
Attached File  6FDF3C08-FB83-4B69-B456-E8FFE5126EB2.jpeg   157.68K   8 downloads
Do the numbers indicate anything in particular?
Thanks.
#2 yel327
  • 13,081 posts
Posted 31 May 2020 - 06:08 PM
No. Only the ID plate on it might help, but would make little difference to value if GMH or imported later
#3 rexy
rexy
  • 3,588 posts
  • Name:Rexy
Posted 02 June 2020 - 10:24 PM
Only interested in identifying it’s likely origin and specs.
These are the only numbers visible.
Front passenger side.
Attached File  EAFC238A-DB26-453A-9282-0EACB7A78419.jpeg   112.38K   5 downloads
Rear drivers side.
Attached File  B127A9A2-04B8-428D-8D93-B2140155BB91.jpeg   75.45K   6 downloads
Attached File  3D22D467-4CBF-4054-AB9F-BEACAA3E6C32.jpeg   52.76K   6 downloads
#4 yel327
  • 13,081 posts
Posted 03 June 2020 - 06:33 AM
No help. Only the little plate on the side will identify if from a Holden or Statesman. The rest is all the same as they all came from a US plant. Not sure how the date codes worked on these. I have two in the shed and there are slight differences in the outer case, not sure of either of their origins either. They were fitted from about 1969 behind a huge array of lower power engines.
Edited by yel327, 03 June 2020 - 06:37 AM.
#5 rexy
rexy
  • 3,588 posts
  • Name:Rexy
Posted 03 June 2020 - 10:04 AM
No plate to be seen. Where should it be mounted?
#6 rexy
rexy
  • 3,588 posts
  • Name:Rexy
Posted 03 June 2020 - 12:19 PM
Were the WB statesman lock up converter units?
#7 yel327
  • 13,081 posts
Posted 03 June 2020 - 12:42 PM
No, that is a TH200-R4.
Neither of mine have a plate either like a Trimatic or TH400. Weird.
#8 rexy
rexy
  • 3,588 posts
  • Name:Rexy
Posted 03 June 2020 - 05:37 PM
This isn’t a lock up unit as no C cast on the front of the case next to the hub. If the WB statesman unit should be a TH 350C then this isn’t a statesman one.
Thanks for having a look.
I like a mystery....
#9 yel327
  • 13,081 posts
Posted 03 June 2020 - 05:45 PM
Statesman don’t lock up afaik. Same as HZ.
#10 yel327
  • 13,081 posts
Posted 03 June 2020 - 06:19 PM
I just had a read that the TH350C has an electrical plug on the LHS. I might look into one of these for my HK if I snot the one I have.
#11 yel327
  • 13,081 posts
Posted 03 June 2020 - 06:28 PM
Also just looked in the WB parts catalogue. It says a TH350 model code is “ink stamped” on the side of the converter housing and a date code on the side of the oil pan.
The sample code given in the catalogue is J9M23D. J means GM of Canada. 9 is 1979. M is August (F,G,I,J,L,N,O,Q not used). 23 is the day. D is the shift (day).
#12 yel327
  • 13,081 posts
Posted 04 June 2020 - 05:43 PM
You've got me interested now Rexy. I'm expecting 450hp or thereabouts out of my 377 SBC. It'll have bulk torque too being a 3.75" stroke. The TH350 I have is not really good for that much, it is really just a heavier duty rebuild on a standard one with a B&M holeshot 3000 converter and a B&M shift kit. I plan to use it to get the car sorted and Engineered, then I was going to get a new one built to suit with a better converter like a V6 4L60 converter modded.
But after I did some research today a TH350C might be a better option. I found a good case and converter today, the rest of it was scrapped though. So I just have to look for another box for the valve body and internals, but I can look for Pontiac ones too as this case is good. The lockup looks to be verily easily controlled using a vacuum switch and a relay off the brake light circuit so the converter only locks in top gear and high vacuum with brakes off. It just needs a 3000rpm converter built from a 4L60 with the TH350 pump snout on it. The rest of the internals of the box other than the extra bit of valve body for the lockup is the same as a TH350. Will make the car far more tolerable on highway cruising with a 3000 or higher stall and a 3:1 or 3.25:1 rear end.
#13 rexy
rexy
  • 3,588 posts
  • Name:Rexy
Posted 05 June 2020 - 06:13 PM
My original plan was to find one but this box crossed my path at an irresistible price. Should be enough to get everything up and running.
Pity there aren’t any lock up TH 400 boxes, would be great for my HQ.
#14 yel327
  • 13,081 posts
Posted 05 June 2020 - 06:41 PM
There are 4SPD TH400 but you need a tranny ECU for it. Pretty sure these are lockup converters. As the late TH400 were called 3L80 once they became a GM Powertrain box (like TH700 became 4L60) the 4spd version was 4L80E as they were all ECU controlled. Normally found in diesel 2500 trucks, the Holden Suburban 2500 had one.
Apparently the TH350C are cheap, the one I got the case from had been wrecked out as they are not really wanted. Case was kept for mockups.
#15 rexy
rexy
  • 3,588 posts
  • Name:Rexy
Posted 06 June 2020 - 02:46 PM
I will probably put a 4l80 in the ute at some stage. Plenty of people have run them without electronics.
#16 yel327
  • 13,081 posts
Posted 06 June 2020 - 03:48 PM
Full manual shift?
#17 yel327
  • 13,081 posts
Posted 06 July 2020 - 07:40 PM
Just picked up a whole TH350C today, and learned that I can control the TCC with the Holley Sniper using the N2O output relays. So going to get one built. Will use the TH350 I have with the 283 and then fit the TH350C with the 377.
#18 rexy
rexy
  • 3,588 posts
  • Name:Rexy
Posted 11 July 2020 - 02:48 PM
Be interested to see how it turns out.
#19 yel327
  • 13,081 posts
Posted 11 July 2020 - 03:04 PM
Here is another 350C
https://www.gumtree....rbox/1252245455
