What PSI should the radiator cap be for a HQ 308 be?
Radiator Cap
Posted 05 June 2020 - 08:05 PM
Posted 05 June 2020 - 08:11 PM
Happy to be corrected though.
Cheers,
Liz
Posted 05 June 2020 - 08:17 PM
Posted 05 June 2020 - 08:55 PM
Posted 06 June 2020 - 08:45 AM
When the HQ was around there were no recovery systems. Also there should be no difference in the cap's psi recovery or not.
All engines from the 173 to the 308 V8 had 13 psi caps as standard from the factory.
This was increased to 15 psi for factory A/C, heavy duty radiators, One Tonners & 350 V8 engines.
I would recommend updating to a recovery system & an increase to 15 psi is always good especially for performance engines.
BTW, VN Onwards Commodore run a 20 psi system.
Dr Terry
Posted 06 June 2020 - 09:35 AM
The higher the pressure, the higher the boiling point (that's why compressed gases, like LPG for example, can be stored as a liquid at room temperature), additives AKA "coolant" can also change the boiling point.
Modern engines tend to run pretty hot in terms of what we're used to seeing with the old red motors mostly due to newer emissions standards, but just remember that older style heater cores (under the dash) aren't rated for modern cooling system pressures, especially when they're 40+ years old!
