Yella terra flywheel issues
#1 _Donyboom_
Posted 08 June 2020 - 07:09 PM
Posted 08 June 2020 - 07:20 PM
Will check the counter bore depth on an OEM red 6 flywheel for you a little later this evening.
#3 _Donyboom_
Posted 08 June 2020 - 07:52 PM
Sorry I should have mentioned that the standard one has a counter bore depth of somewhere around 9mm. Why would yt change this? Or am I supposed to use different bolts?
Posted 08 June 2020 - 07:58 PM
You would be best contact Yella Terra and inform them of your situation.
#5 _Donyboom_
Posted 08 June 2020 - 08:00 PM
Posted 08 June 2020 - 08:16 PM
Wouldn't be surprised if they expect you to use aftermarket ARP bolts or something like that. The V8 flywheels are basically just Chevy ones with Holden offset bolt pattern, when you compare weights the lightweight one is slightly heavier than standard as all the comparisons are for different engines, I'd say they've just taken parts off the shelf to suit rather than being ground-up made for the application.
Posted 09 June 2020 - 12:05 AM
#8 _Donyboom_
Posted 09 June 2020 - 12:39 PM
So as it turns out, I have discovered an error in the flywheel machining and they will be changing them from now on. No worries folks! thanks for the input!
Posted 09 June 2020 - 01:18 PM
