Hey Guys,
I am having immense trouble trying to find out if CAE Tri Y Headers will fit into my LX with AFR cylinder heads.
The problem is that CAE make the headers to suit standard cast heads and the AFR heads run a exhaust port which is at a higher point.
Has anyone had this issue and can they be fitted or is there another off the shelf option without getting Custom headers made and the huge expense that goes with that.
TIA
Craig
