Just working on the HK's fuel system so I can get the tank back in. A question in red bold below.
Pictures tell the story mostly. I'm using a VY-VZ regulated MRA as a dead-head feed to a Holley sniper. The picture shows a dummy setup how it is connected. The filter and fuel lines are new VZ, the fuel feeds the filter, feeds the fuel to the front of the car via the T-piece on the filter output and the MRA regulates the pressure with return to the tank.
Tank1.JPG 221.48K 1 downloads Tank2.JPG 171.1K 1 downloads
I also bought a standard VZ bracket that holds the filter, the clamp comes with the filter. I plan to use this to mount the filter:
Bracket.JPG 258.61K 1 downloads
This is how a standard HK fuel line looks below and above the floor (tank missing from the car of course). The line comes through a 20-odd mm grommet.
Line1.JPG 245.61K 1 downloads Line2.JPG 158.98K 1 downloads
So I was wondering. Is it OK to mount the filter inside the boot of the car? Or should it be under the car? The standard VZ feed and return lines I have would work with it in the boot, but obviously I'll have to make up lines if the filter is under the car. If the filter is in the boot I'd simply run a hose off the T on the end of the filter to the factory fuel line. If the filter goes under the car I'll cut the factory fuel line back away from the tank and re-flare it so it can connect to the filter outlet.
If the filter goes under the car I'd make up lines and use 90deg bends to get the fuel lines through a floor grommet, probably one of these:
o-rings.JPG 257.78K 1 downloads
The factory fuel VZ lines looks like some sort of plastic stuff. Anyone know where to buy it if I have to make some up?
Hose1.JPG 143.13K 1 downloads
I have the hose ends if I have to make some up, just not and 90deg fittings:
Connectors.JPG 219.83K 1 downloads
The smaller fitting will run a pipe across the front of the tank and join at a T piece to the HK filler neck vent and run through the factory HK breather grommet to a canister in the engine bay (turfing the steel breather line). If I can buy this plastic hose in the smaller size I might use that and run it all the way to the engine bay. There are clip holes along the inside of the passenger side sill that must be for LHD fuel and brake lines as they mirror the ones on the driver's side. HK standard tank breather (open to air above the diff):
breather.JPG 170.91K 1 downloads
Edited by yel327, 10 July 2020 - 04:03 PM.
