LJ lefthand mirror
25 replies to this topic
#1 Liz Clare
Liz Clare
  • 679 posts
  • Car:LJ GTR XU1 and LX SS
Posted 14 July 2020 - 01:51 PM
G'Day,
Anybody have the measurement for where to drill holes for lefthand side mirror on an LJ?
Is it the same on both sides?
Can't find anything in parts manual or online..
Cheers,
Liz :)
#2 lx308
lx308
  • 2,838 posts
  • Name:Tony
  • Car:2005 CV8 Monaro
Posted 14 July 2020 - 02:24 PM
Surely be the same both sides?
Attached File  Screenshot_20200714-122258_Photos.jpg   106.16K   14 downloads
#3 Liz Clare
Liz Clare
  • 679 posts
Posted 14 July 2020 - 04:22 PM
Yes, it should be but thought I’d ask the question just in case it’s different. I don’t want to have multiple drill holes if I get it wrong
Cheers,
Liz
#4 RallyRed
  • 7,840 posts
Posted 14 July 2020 - 08:03 PM
Hi Liz,
If you are putting the LHS mirror on Pinky for track work...you could consider an alternative like this ( not sure this is exactly the one I have).
Clips on/off over the existing rear view mirror. I have one in the green Nc car, fantastic bit of gear. You can pretty well see out of the rear window AND both side windows, from the rear vision mirror.
Prob. a bit ugly for road us, but great on track.
Edited by RallyRed, 14 July 2020 - 08:04 PM.
#5 Kevrev
Kevrev
  • 409 posts
  • Name:Kevin
  • Car:73 LJ GTR, 77 LX SS 253 Manual
Posted 14 July 2020 - 08:23 PM
I don't have a measurement, but here's a pic of an old GTR I used to own. Looks like a good match for the drivers side position
#6 S pack
  • 15,538 posts
Posted 14 July 2020 - 09:30 PM
Projecting a line down the edges of the door division channels we can see the top rear corners of the mirror pads are positioned basically the same on both doors.
Attached File  LJ LH mirror position.jpg   162.27K   10 downloads Attached File  LJ RH mirror position.jpg   100.65K   9 downloads
#7 Liz Clare
Liz Clare
  • 679 posts
Posted 15 July 2020 - 12:03 PM
Hi Liz,
This is a great idea, Col. I will indeed get one. I already have a slightly bigger than standard unit in the pink car from when it was raced previously but the more vision the better for a learner like me :D
LH mirror already purchased as well so it will be installed as I really find the odd mirror on only one side a bit annoying ;)
Thanks for the tip.
Cheers,
Liz :)
Thanks Kev, that's a great help :)
attachicon.gifLJ LH mirror position.jpg attachicon.gifLJ RH mirror position.jpg
Thanks a bunch Dave, this helps a lot. Much appreciated :)
Cheers,
Liz :)
#8 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 15 July 2020 - 07:16 PM
G'Day,
Cheers,
Liz :)
I didn't think that there was dealer instructions for fitting Liz, but if you mark it out & have someone place the mirror in proposed position, ie holding it there for you, you should be able to check out your vision & if it's all good. Install it mate Gary.
Pretty sure Rob mirrored the position on his car & seems all good.
#9 S pack
  • 15,538 posts
Posted 15 July 2020 - 07:46 PM
I expect GMH would have supplied fitting instructions with the NASCO left hand door exterior rear view mirror accessory package.
#10 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 16 July 2020 - 06:43 PM
not trying to hijack this post
but is the lc the same right to left
#11 claysummers
claysummers
  • 3,325 posts
  • Name:Clay
Posted 16 July 2020 - 07:08 PM
This is the same mirror fitted to EH isn’t it bat? They have to be mirror images, no pun intended.
#12 rodomo
  • 17,998 posts
Posted 16 July 2020 - 09:59 PM
O'l mate put one on the left, same as original right, could hardly see the mirror? LC
#13 Liz Clare
Liz Clare
  • 679 posts
Posted 17 July 2020 - 09:40 AM
Yep, not much mirror to look at on those LC ones.
I had the same little round driver's side mirror on a HG and it was mostly a waste of time trying to see anything. Big lump of a car with a little tiny mirror looked ridiculous  :tease:
Cheers,
Liz :)
#14 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 17 July 2020 - 10:06 AM
not sure about eh but on hr
#15 claysummers
claysummers
  • 3,325 posts
  • Name:Clay
Posted 17 July 2020 - 10:47 AM
Next photo shows there is a very slight twist between door mount and mirror boss0b1b37acdda900f5d1b1b9d38570a6b8.jpg
They are slightly asymmetrical although to be honest I think you would be hard pressed to notice it on the car. Could be wrong of course.
#16 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 17 July 2020 - 05:39 PM
Pretty sure that is correct mate, yes !
#17 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 17 July 2020 - 05:59 PM
I was assuming that you where meaning where the mounting positions the same left to right there bat. Which is correct. However if you mean the stem. They are left & right ie different part numbers mate.
#18 RallyRed
  • 7,840 posts
Posted 17 July 2020 - 10:29 PM
Are not LC's single mounting hole,at leading edge of door?
Edited by RallyRed, 17 July 2020 - 10:30 PM.
#19 S pack
  • 15,538 posts
Posted 18 July 2020 - 07:11 AM
LC has two holes. One for bolt the other for the alignment pin.
#20 bat 53
bat 53
  • 492 posts
  • Name:albert
  • Car:lc gtr
Posted 18 July 2020 - 10:24 AM
yes i know that there are right and left stems
i am asking about mounting positions
thanks for the replies
cheers  bat
#21 Liz Clare
Liz Clare
  • 679 posts
Posted 14 August 2020 - 12:35 PM
Chinese crap mirror cost $225 from Muscle Car Parts...
Attached File  Broken glass from MCP Mirror copy.jpg   187.4K   8 downloads
The glass fell out the first time the door was closed...
Attached File  MCP Mirror without glass.jpg   88.64K   8 downloads
and I was left with a mirror head without glass.
Lucky I had an old HQ mirror head.
Buy Australian if you can. F@K the Chinese!
Cheers,
Liz :)
#22 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 14 August 2020 - 06:01 PM
Oh no ! That's no good Liz, lucky you have the back up. Don't get me started on the chinese though, i often wonder if they themselves also call it chinese shit.
#23 sibhs
sibhs
  • 2,702 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 14 August 2020 - 11:20 PM
Hi Liz,
this happened to mine and MCP were happy to give me another one once they had confirmation of receipt and received the broken one. The second mirror head had a stronger mirror fixing.
Mine fell out while my wife was adjusting it doing 110kph on the HWY.
Marty
Edited by sibhs, 14 August 2020 - 11:21 PM.
#24 Liz Clare
Liz Clare
  • 679 posts
Posted 15 August 2020 - 08:48 AM
Hi Liz,
Marty
Oh thanks Marty. I’ll contact them and see what happens. Hopefully the workshop still has the mirror head, I’m assuming they would’ve swept up the glass though.
Cheers,
Liz :)
#25 sibhs
sibhs
  • 2,702 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 15 August 2020 - 09:53 AM
They don't want the glass back!
If I had to guess - It looks like they've had a few of these and they're getting mirror glass cut and fitted in Australia to all the returns. (the mirror edging looked slightly different)
Marty
