LC GTR interior badge location?
12 replies to this topic
#1 _Donyboom_
_Donyboom_
Posted 23 July 2020 - 09:13 AM
Gents,
            Can anyone give me a reasonably accurate position of the interior door trim badge location and the method of fixing. I bought a Winners trim set and rare spares badges and wondering what others have done to fix the badge as the pins are quite long. I realise the original badges were probably part of the door skin.
#2 sibhs
sibhs
  • 2,703 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 23 July 2020 - 10:43 AM
Hi Don,
I've measured 6 and a quarter inches from hole centre to edge of GTR Badge and half inch from trim line to bottom of GTR Badge.
As to fixing them, I'm yet to get to that stage.
Good luck and please post your results on here.
Marty
Attached File  IMG_2005.jpeg   87.01K   11 downloads
Attached File  IMG_2006.jpeg   84.34K   5 downloads
Attached File  IMG_2007.jpeg   109.54K   7 downloads
Attached File  IMG_2008.jpeg   112.02K   6 downloads
#3 _Donyboom_
_Donyboom_
Posted 23 July 2020 - 11:25 AM
You bloody legend! Cheers bud will let you know how i go!
#4 _Donyboom_
_Donyboom_
Posted 23 July 2020 - 11:32 AM
Yeah so now the query is. How do you mount the badge so that the pins don't foul on the door skin?  :blink:
#5 S pack
  • 15,539 posts
Posted 23 July 2020 - 12:11 PM
The pins on the trim badges are shorter than the exterior badges. A flat washer is installed over the pin on the backside of the trim board and the pin is then peened over the washer.
Edited by S pack, 23 July 2020 - 12:11 PM.
#6 _Donyboom_
_Donyboom_
Posted 23 July 2020 - 12:22 PM
Ok then it sounds like I have the incorrect badges. Does anybody know where to get the correct badges as rare spares thinks they are all the same...
#7 S pack
  • 15,539 posts
Posted 23 July 2020 - 12:26 PM
I suspect it will be a matter of shortening the pins on the new badges to make them suit.
#8 S pack
  • 15,539 posts
Posted 23 July 2020 - 12:29 PM
Perhaps ask the trimmers what they do when the make reproduction GTR door trims.
#9 _Donyboom_
_Donyboom_
Posted 23 July 2020 - 12:32 PM
Yes i may have to come up with a solution. Yep thanks will do. I rang winners and they are busy at the moment and will get back to me.
#10 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 23 July 2020 - 08:11 PM
You may be able to cut the pins 3mm past the door card , cut a groove around the end of the pin and use a star clip like this.
#11 IMORAL
IMORAL
    Bored
  • 2,567 posts
  • Name:Paul
  • Car:LX SS HATCH - IMORAL
Posted 24 July 2020 - 01:35 PM
You cant buy the 'correct' ones for the door cards. And original ones cost a fortune. When you can actualy find them.
#12 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 25 July 2020 - 02:44 PM
On a side note,if you have the "Original" GTR badges rather than grind the rivets off at the back ,cut down the old trim and remove the badges with the rivets still in place ,that way you can refit to your new door trim using circlips .
Edited by Indy Orange, 25 July 2020 - 02:49 PM.
#13 _LONA-CK_
_LONA-CK_
Posted 28 July 2020 - 11:23 AM
I have 2 original 2810504 LC GTR door trim badgers in great condition $320 insurance posted to your door, message or call my number if interested 0478847765.
Ps the best way to put these back on a trim is by doing what he ^^^ Indy Orange (Paul)  has said cheers gong
