I have never had L34 steering arms to try or to see how they differ to the Harrop ones so no. I'm not sure where I would get any either. I was of the understanding they were like the Harrop ones but with the steering stop on them
Is that what you mean by L34 setup?
If you mean the rest of the setup as per which stubs, position of UCA, camber etc, I probably did as I checked many many combos. I didn't bother with some that I could see were going to be really undesirable.
I actually found all the ones I posted on Cardomain they are still there but they must have compacted all the photos as I can't read the legend on them now when I blow them up. I bought my work PC home as it has a DVD drive on it do I can check my archives from 4 PCs ago.
I should still have the .xls data if I'm lucky.
M@
I was just interested, I could never find any when I did my original install using the LH type front end and HQ stubs/brakes. I had a full NOS L34 chassis kit minus the engine bits, it had stubs, rotors, calipers, hoses, rear brakes, axles, upper complete control arms (attached to stubs) and front springs. But no steering arms IIRC. I always assumed the front crossmember was the same as it didn't come with it. I don't know why it had upper arms, maybe bushes were different? I didn't use that stuff as I never wanted to waste it on a low-ish model LX hatchback, so I copied it all using standard Holden stuff but used the standard LH steering arms which as I said had significant bump steer.
As Laurie says, your research would be great for a sticky thread here if you ever get the motivation and time to put it up.
