Wonky trans tunnel LJ
10 replies to this topic
#1 Mattyj33
Mattyj33
  • 18 posts
  • Name:Mat Jackson
  • Car:LJ 2 door, had an LC 4 door
Posted 06 August 2020 - 06:49 PM
Hi Guys, I have noticed my trans tunnel slopes down on the drivers side (ie: lower than the passanger side) just in front of where the manual shifter hole is. The tunnel was butchered by some monkey with a hammer and tin snips at some point, both reinforcing plate and tunnel, but i beat the reinforcing panel back to shape (at least I thought I did) and put in a replacement tunnel section. Everything seemed to fit well, with exception of the height difference. I only had surrounding, unmolested tunnel for reference, so every chance I've got it wrong, but though i'd better check before adjusting it.
Any help is good help fellas.
Cheers,
Mat
#2 skap
skap
  • 1,049 posts
  • Name:Skap
  • Car:Mighty VN
Posted 06 August 2020 - 07:14 PM
Geno is the man to talk to about tunnels.
Username: ICE
#3 rodomo
  • 17,998 posts
Posted 06 August 2020 - 10:05 PM
Can you post up some pics?
#4 Mattyj33
Mattyj33
  • 18 posts
  • Name:Mat Jackson
Posted 06 August 2020 - 10:54 PM
I'll try and grab some tomorrow, the ones I have don't show the angle
#5 Mattyj33
Mattyj33
  • 18 posts
  • Name:Mat Jackson
Posted 07 August 2020 - 09:53 AM
Here a couple pics. It's a little hard to see in photos, but definitely slopes down towards drivers side.Attached File  20200807_095202.jpg   112.83K   3 downloads
#6 Mattyj33
Mattyj33
  • 18 posts
  • Name:Mat Jackson
Posted 07 August 2020 - 09:55 AM
And is lower than just behind the shifter hole
#7 rodomo
  • 17,998 posts
Posted 07 August 2020 - 10:54 PM
Looks a bit like the welds might have pulled it?
#8 Mattyj33
Mattyj33
  • 18 posts
  • Name:Mat Jackson
Posted 07 August 2020 - 11:28 PM
Yeah, possibly. I did go very slowly with the welds and kept the temps down, but if it's ment to be flat across there I'll try planishing them and see if it comes back up. Otherwise it's a pretty easy fix, I just wanted to confirm what I thought was right before I fixed something that wasn't broken.
Thanks for the help, it's always appreciated
Cheers,
Mat
#9 rodomo
  • 17,998 posts
Posted 08 August 2020 - 10:29 PM
Have a look at this blokes work:
http://www.gmh-toran...-7#entry1055087
#10 jpxu1
jpxu1
  • 548 posts
Posted 08 August 2020 - 10:49 PM
A couple of the pics you are after, but not the answer you are hoping for I'm afraid.
Attached File  Torana Tunnel #1.JPG   125.62K   6 downloads
Attached File  Torana Tunnel #2.JPG   121.29K   5 downloads
Cheers,
JPXU1
#11 Mattyj33
Mattyj33
  • 18 posts
  • Name:Mat Jackson
Posted 10 August 2020 - 04:25 PM
Thanks guys, very helpful. I got it sorted and all nice and flat now, just need to recut the shifter hole properly.
I really appreciate the effort for the replays, thanks again
