308 build suggestions
#26
Posted 21 August 2020 - 04:59 PM
dont need histall and will give plenty of power for a mild 308 engine
each to there own
#27
Posted 21 August 2020 - 05:03 PM
#28
Posted 23 August 2020 - 12:27 PM
Best simple street combo for a B cast style headed 308 is flat tops and a cam with about 230 @ 50 duration. So about a Crane 286. A Performer manifold, 650 holley or well set up Quady, and a good exhaust with exctractors. You are looking at around 300hp and it will be reliable and reasonably economical and enough power to have a bit of fun with.
I had this combo in the old LX as my daily driver for ten years. Excellent street combo that I drove in heavy city traffic and long highway trips without missing a beat.
While a hydraulic roller is a very nice thing it’s not necessary for what you want and offers no real advantage for its extra cost over a good old hydraulic flat tappet cam for your application.
#29 _Lazarus_
Posted 24 August 2020 - 08:51 AM
The 286 has a very good reputation for a street cam. Did you see this thread -
http://www.gmh-toran...and-hp-figures/
#30 _JJ21_
Posted 25 August 2020 - 09:42 AM
So Rexy what trans/stall did you have behind this combo?
#31
Posted 26 August 2020 - 12:38 AM
Initially had a steel case celica box (fantastic shift feel) followed by a supra 5 speed.
Rear end was initially a banjo. This motor broke a 3.08 crown wheel and pinion and then a couple of axles. After trialling some 3.36 banjo gears I bit the bullet and put a 3.5 LSD nine inch in it.
Your auto will be easier on the rear end. If you like cruising a relatively small converter should be ok.
