HQ CALIPER AND DISC TORANA STUB
16 replies to this topic
#1 MRGMH
MRGMH
  • 228 posts
  • Name:Torana
  • Car:LJ
Posted 15 August 2020 - 11:49 AM
Hello boys and girls.
I think I have this right but still would love some clarification.
I want to run hq disc and Calipers on my standard lx torana stub.
Is it as simple as buying new hq discs then getting them machined 6mm off the diameter?
Hq caliper boot straight up to torana stub?
Also which H series caliper are the best to use?
Also what side should the caliper be mounted on? Towards front or rear of car?
Does this setup hit anything on full lock?
#2 claysummers
claysummers
  • 3,327 posts
  • Name:Clay
Posted 15 August 2020 - 12:32 PM
Here we go yet again.....
#3 Ice
  • 15,122 posts
Posted 15 August 2020 - 12:39 PM
There is multiple threads on this subject
search
#4 MRGMH
MRGMH
  • 228 posts
  • Name:Torana
  • Car:LJ
Posted 15 August 2020 - 01:26 PM
Jesus you blokes wonder why people don’t ask on here anymore. The search function is shit and half the replies are all jumbled up and people replying to various other questions not in order. either offer some advice/help or move along?
#5 claysummers
claysummers
  • 3,327 posts
  • Name:Clay
Posted 15 August 2020 - 01:39 PM
That’s because every time someone asks a question they start a new thread. Agree about the search function but the solution to that is to use google etc. it will bring you to the relevant topic on this forum.
#6 Statler
  • 6,282 posts
http://www.gmh-toran...rsion-tutorial/
#7 claysummers
claysummers
  • 3,327 posts
  • Name:Clay
Posted 15 August 2020 - 01:46 PM
Some light reading for you
http://www.gmh-toran...ake-conversion/
http://www.gmh-toran...o-my-torana-lh/
http://www.gmh-toran...-brake-upgrade/
http://www.gmh-toran...-down-hq-discs/
http://www.gmh-toran...e-on-full-lock/
http://www.gmh-toran...n-torana-stubs/
http://www.gmh-toran...3225-hq-brakes/
http://www.gmh-toran...pgrade-options/
#8 MRGMH
MRGMH
  • 228 posts
  • Name:Torana
  • Car:LJ
Posted 15 August 2020 - 02:06 PM
Thanks most of them are hq stub. I’m keeping my torana stubs as ride height is spot on.
Only one of those mentions lx stub and then doesn’t go into much detail.
#9 rexy
rexy
  • 3,587 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 15 August 2020 - 05:08 PM
Torana stubs use the same bearing as HQ so fit no problem. Might as well re grease them while it’s apart.
Make sure you use new discs or you will need to machine the entire pad area as the contact wear area on a HQ is different to when you fit them on an LX. On Torana stubs the wear area extends closer to the hub.
You need to machine 6mm off the radius, so 12 mm off the diameter.
Going to run HQ pattern wheels? No problem.
Going to run Torana pattern? Budget for drilling new pattern.
Leave the calipers on the front.
Caliper choice? The steel HQ ones are fairly small. Minimal if any grinding required.
Alloy LX ones fit with the addition of HX pad carriers. Not loved by many here but from personal experience are fine for a street car.
Others have used alloy girlocks. I have these on my LC.
May or may not need to grind the inferior metal edge of the pad (the edge closest to the spindle of the stub axle) so it doesn’t rub on the disc hub.
Dont mind the grumpy folk. They are an invaluable source of information that isn’t replicated anywhere else. I have received lots of excellent expert help over the years!
#10 axistr
axistr
  • 1,169 posts
Posted 15 August 2020 - 06:07 PM
I have a pair of HQ slotted front rotors, (Torana stud pattern) machined so they are 6mm reduced off the OD. The calipers are alloy I was told  they were from a HX. I also have stainless brake hoses for them. The discs are like new, The calipers had new pistons and kits fitted when I restored the car, but at the time of removal they started to get a bit sticky when cold. My hatch only got out a few times a year so that was more than likely the problem. (to much sitting around time) I was running 14" x 8" wheels. Upgraded my wheels to 17" and decided to fit 300mm brakes. If they are any use to you flick me an offer.
Cheers Lenny.
#11 mitchg
mitchg
    The guy with the Torailer
  • 3,111 posts
  • Name:Mitch
Posted 16 August 2020 - 08:31 PM
Rexy,
These questions have been answered a thousand times in all of the threads, but there is so much info in them that it can still be daunting to find what works definitively. Thank you for your response, it has all the info required without the headache.
#12 Westside Performance
  • 72 posts
  • Car:Hatch
Posted 12 July 2021 - 07:20 AM
Sorry to bring up an old thread fellas, but I have attempted the HQ vented disc conversion using the Torana Stub, UC steering arm and HQ rotor turned down 6mm off the radius.
It was a huge failure.
I bought the A9X style large Girlock alloy callipers, reco'ed them, clearanced them just like everyone else showed on this forum but mine did not even come close to fitting due to insufficient tie rod clearance.
So now I am on the market for a new set of calipers that will work with my front end.
Just to be 100% so I don't buy the wrong callipers again, what are my caliper options here?
From the reseach I've done on this forum, it appears I can only fit 2 types of calipers:
These are the PBR HQ cast iron callipers with the sliding pins and large external clip retainer
OR the PBR alloy calipers.  Is this correct?
#13 rexy
rexy
  • 3,587 posts
  • Name:Rexy
Posted 12 July 2021 - 08:12 AM
Which model torana are you doing this on?
#14 Statler
  • 6,282 posts
Posted 12 July 2021 - 08:29 AM
Might be easier to buy the recommend Harrop steering arms.
#15 Westside Performance
  • 72 posts
  • Car:Hatch
Posted 12 July 2021 - 08:45 AM
Doing this on a UC that is being converted to LX.
Those Harrop arms are selling for $300 each now and that is a little too expensive
#16 rexy
rexy
  • 3,587 posts
  • Name:Rexy
Posted 12 July 2021 - 01:14 PM
Then the steel HQ or HX long slide are the go.
#17 Westside Performance
  • 72 posts
  • Car:Hatch
Posted 13 July 2021 - 09:21 AM
Cheers Rexy
