Hi Guys,
Can anyone help with any details whatsoever of an LC coupe just off the body number? All tags are missing... :(
Posted 18 August 2020 - 08:24 PM
Hi Guys,
Posted 18 August 2020 - 11:56 PM
Posted 19 August 2020 - 09:42 AM
Thanks, it is LC09093B
Posted 19 August 2020 - 09:54 AM
Posted 30 September 2020 - 02:13 PM
That is the chassis number. Body number is on the body tag. If it has no tags it is just an LC coupe, do as you wish with it. Perfect body to go to town on with V8 etc, no-one will be offended.
I think the body number is 2394-BChuck the body number up someone will chime in and give you some info
Posted 30 September 2020 - 09:26 PM
More precisely we need the Model Number off the body ID tag to ID it. Where did the 2394-B body number come from if the tags are gone ?
Also without being too picky, there were no LC coupes built except one prototype, 2 door LC/LJ Toranas are "2-door Sedans".
Dr Terry
Posted 30 September 2020 - 09:49 PM
Posted 01 October 2020 - 07:26 AM
Chassis number LC09093B aligns with a build date of April 1970.
Hard to guess a body number without knowing if the car was from the Acacia Ridge or Pagewood assembly plant.
Posted 01 October 2020 - 07:40 AM
Posted 01 October 2020 - 08:03 AM
Torana assembled at Pagewood used bodies built at Acacia Ridge hence why Pagewood Torana have chassis numbers from the Acacia Ridge sequence.
At the end of the day, trying to nail a body number for the chassis number is only ever going to be an educated guess.
No amount of guessing numbers is going to lead to discovering the cars factory assigned PSN.
As has been said before. In the absence of all tags it is just a 2dr Torana, modify it to your hearts desire.
Edited by S pack, 01 October 2020 - 08:04 AM.
