Finalising getting the tank into the HK with a new box sorted for the EFI filter in the boot. Went to order some fittings and EFI hose to connect over to the original HK fuel line, which is 5/16”. Is this big enough for a 425-450hp 385ci EFI engine? Fuel pressure will be regulated to 60psi at the pump.
If not, I’ll get some 3/8” alloy fuel line and bend it up to follow the original line’s path, the inner sill clips I have will take 3/8” line easily. I’ll stop it short of the hole/grommet where the original enters the boot and run rubber out to it. Andy Lee said he can make me up a 3/8” spring to protect the line like the original 5/16” line does where it enters the rear wheel arch region.
Holley Sniper has an AN6 fitting on it.
Main question is, can I buy fittings to go on either end of the 3/8” alloy tube that finish it off in a standard barb fitting so I can attach 3/8” EFI hose? If so what are they called? Or can alloy tube be flared suitable for hose? I have a really nice flaring tool for steel bundy tube for brake lines, not sure if it will do alloy tube. Aeroflow have alloy tube and some olive fittings, not sure if these work on alloy tube?
Edited by yel327, 20 August 2020 - 09:20 PM.
