Gearbox cross member bolts
12 replies to this topic
#1 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 07 September 2020 - 06:43 PM
Yes I know I'm being a dick but please entertain me and view the photo of the two bolts. Top bolt is one of three (3) that secures the gearbox cross member to my 5/72 XU1. The bottom bolt is the fourth (4th) which is the odd one out? Yes I know I'm probably the true odd one out but I want to replace that 4th bolt with an OEM bolt which is the same as the rest. Anyone silly enough to sell me one of these????
#2 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 07 September 2020 - 07:56 PM
I can only see 1 photo, but the 1 on the left looks more like factory correct, to me. With the "s" on it !
#3 jd lj
jd lj
  • 2,102 posts
  • Name:James D
  • Car:LJ SVO
Posted 07 September 2020 - 08:30 PM
From memory the gearbox cross member to chassis rails bolts have a taller head than std bolts. The one on the left looks more like it from what I can see. The flat washers are thicker than std washers too.
#4 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 07 September 2020 - 08:34 PM
The bottom bolt with the letter 'F' is the odd one that I want to replace if someone has one (like the top bolt) they can send me. Happy to pay for the inconvenience???
#5 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 07 September 2020 - 08:37 PM
On a laptop the bolt photo is vertical not horizontal (left or right).
#6 crabba67
crabba67
  • 903 posts
  • Name:anthony
Posted 07 September 2020 - 09:09 PM
Mark the one on the left indented hex head.
#7 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 08 September 2020 - 05:21 PM
I subscribe to the theory that if you rectify something little on the Torana every week/month then a lot of things can be achieved at the end of a year. Anyone at all want to sell me one of these? will pay $30 for your trouble?
#8 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 08 September 2020 - 07:12 PM
These are the dimensions. Once again I apologize for the insignificance of this post. You'd think I'd have something more important to worry about  :mellow:.
#9 lx308
lx308
  • 2,838 posts
  • Name:Tony
  • Car:Nuffin. Goin touring.
Posted 08 September 2020 - 08:49 PM
I'll have a rummage through the shed tomorrow. Might be lucky.
#10 lx308
lx308
  • 2,838 posts
  • Name:Tony
Posted 09 September 2020 - 12:29 PM
No luck. Have a few bolts the same, but only 30mm length & 5/16th thread
#11 MFM
MFM
  • 687 posts
  • Name:Mark
  • Car:xu1
Posted 09 September 2020 - 05:38 PM
Thanks for trying Tony, appreciate it!
#12 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 09 September 2020 - 08:24 PM
You're spot on there mate, I worked for a guy years ago, his friend always said that you need to spend 30 minutes minimum everyday, whether it's phone calls, research, cleaning stuff, buying ect. To achieve a good result, in a time frame. & there is a lot in a car.
#13 hanra
  • 10,839 posts
Posted 09 September 2020 - 08:42 PM
Yeah I dedicated 2 hours each day after work to my build. And also 8-10hrs every Sat/Sun... got it done in 18 months. I’d just choose one small project at a time and do my best not to move on to anything else until I was satisfied that project was completed.
