Fuel tank dent removal
13 replies to this topic
#1 _Chrisso_
_Chrisso_
Posted 13 September 2020 - 11:10 AM
Hi All, Just curious on removing a big dent in my fuel tank ,I've done it with air pressure and heat on dirt bike expansion chambers but not fuel tanks ,any one got any idea's that worked for them ?? TIA
#2 Cook
Cook
  • 1,534 posts
Posted 13 September 2020 - 12:21 PM
Hi Chrisso.  I had a few dents in mine and ended up taking it to a radiator place and they split it, fixed the dents cleaned inside and resealed and checked.  Cheers Ron
#3 _Chrisso_
_Chrisso_
Posted 13 September 2020 - 12:46 PM
Cheers ,I've just put some air pressure into it & have removed the large portion of the dent quite easy ,but to get the creases out I think the radiator shop is the go, thanks again
#4 Cook
Cook
  • 1,534 posts
Posted 13 September 2020 - 01:13 PM
No worries.  Good luck with it. Cheers Ron
#5 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 13 September 2020 - 02:55 PM
Hey Chrisso, when I got mine done, they just cut the hole in the top, done what was required ect. Weld never to be seen unless I drop the tank. Rainman
#6 DMLC71
DMLC71
  • 424 posts
  • Name:Daz M
  • Car:1971 LC 4 door
Posted 13 September 2020 - 04:28 PM
Split the tank is the only way if you don’t want to use too much filler
#7 sibhs
sibhs
  • 2,724 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 13 September 2020 - 08:52 PM
I got mine fixed by a spot weld dent puller.
#8 _LONA-CK_
_LONA-CK_
Posted 14 September 2020 - 08:36 AM
I have a easy beat great for fuel tank dents.
Cheers gong
#9 Maximart2
Maximart2
  • 19 posts
  • Name:Martin
  • Car:LC GTR
Posted 15 September 2020 - 05:47 AM
Years ago, well some where around 1980, I was fixing some small pinhole rust holes in the top of my LC tank. The top was also very dished because of the usual weight from years of stuff being dropped onto the boot. Drained it, left it out in the sun for a week to gas off and used an oxy to weld them up. Didn't want to put water in it too check for leaks so poured in some paint thinner. It showed up a couple of spots I missed so without thinking I lit up the oxy to fill them and the resulting explosion not only scared the poo out of me but wonders of wonders, had blown the dished tank top flat again! Oh to be young and bullet proof again!
#10 sgo90
sgo90
  • 17 posts
Posted 15 September 2020 - 06:24 PM
What about those "paintless dent removal" dudes if they go in through the sender opening?
#11 _Chrisso_
_Chrisso_
Posted 21 September 2020 - 11:00 AM
Yeah not sure , I'm open to all options as alot of guru's on here have done it somehow over the years,cheers
#12 gtrboyy
gtrboyy
  • 3,241 posts
Posted 21 September 2020 - 06:34 PM
Radiator places can hot tank & flush it so will be safe afterwards to easy beat,pdr or weld/dolly safely
Heard of some welders/fabricators hook up car exhaust into a tank for 20-30mins then weld them up...thought that was a myth untill saw Dominator of StreetOutlaws do it on fb clip lol
#13 _Chrisso_
_Chrisso_
Posted 22 September 2020 - 08:29 AM
Yeah right ,Interesting way to delete the fuel fumes,  I like it cheers
#14 Rainman
Rainman
    Pain in the ar$e
  • 799 posts
  • Name:Ray
  • Car:SS Hatch
Posted 23 September 2020 - 04:42 PM
What about some coca cola and mentos ?
