hi im im the middle of a ls conversion can someone point me in it right direction, ive got my drop tank in getting the fuel pump installed running a return less pump from efi hardware ,now how has evereyone run there fuel lines and fuel tank vent line my motor is out of a vf so do i use the carcoal canister/ purge tank from that or something else???? photos would help
ls conversion fuel system
Posted 13 September 2020 - 12:03 PM
Posted 13 September 2020 - 12:57 PM
Posted 13 September 2020 - 06:55 PM
I have a VT-VZ type pump mounted in a drop tank.
Has a return, vent and supply connection on top of the pump. The vent connects to the original vapor separator thing mounted just fwd of the tank,
P1110660.JPG 158.19K 1 downloads
The supply goes to the filter mounted next to the rear spring
P1110658.JPG 156.67K 1 downloads
And the return comes back from a T-piece connection just after the filter. Works fine so far.
P1110663.JPG 156.08K 1 downloads
Posted 13 September 2020 - 07:21 PM
Out of interest, is that vapour thingy just in front of the tank simply to group multiple tank vapour points back to one line to go forward to the canister?
Posted 13 September 2020 - 07:51 PM
I think that is what it is for,
I have the VZ canister mounted under the guard on a bracket off the front bumper bar
Posted 13 September 2020 - 08:08 PM
