does the trimatic have to come out to put in a full manual valve body?is it straight forward or is it a specilized job from a automatic transmisson shop,
trimatic
lawn bowls
, Sep 13 2020 08:06 PM
2 replies to this topic
Posted 13 September 2020 - 08:06 PM
Posted 13 September 2020 - 09:53 PM
Yes no yes
Posted 14 September 2020 - 11:00 PM
Some kits can be done without removing the box from the car, if you chose to use a higher pressure spring in the pump the box will have to be removed.
You may also have to remove the rear extension housing & the rings from the governor hub depending on kit instructions.
