Good evening all
About to start putting my 186 into the lh which has the 4 cyl K frame
Does anyone do an adaptor Mounts for these ?
Posted 30 September 2020 - 04:15 PM
Good evening all
Posted 30 September 2020 - 08:44 PM
Opel or starfire 4 cyl ?
If its starfire... the 6 bolts straight in
Posted 01 October 2020 - 11:02 AM
Posted 01 October 2020 - 12:16 PM
Adapter ? No.
Cut the mounts off & weld on the 6/V8 mount.
Posted 01 October 2020 - 12:32 PM
Posted 01 October 2020 - 08:28 PM
Yeah I've seen the weld on brackets
Rodshop used to do bolt ons to suit V8... which should technically also suit 6
Might pay to give them a call
Posted 01 October 2020 - 09:07 PM
Posted 02 October 2020 - 05:04 AM
The adapters aren't ideal and I'm not sure anyone supplies them any more (think it was either Rare Spares or CRS), would be best to change them properly/permanently as above. If you do go with the adapters, they probably need a small slot machined in them to allow clearance for the ear of the mount itself otherwise it won't sit down flat.
This is the only photo I can find, you can't see the area to be slotted from this angle but you can see how low the protruding piece is and the mount needs to sit flat on top of this.
Posted 02 October 2020 - 05:25 PM
Hi
I got the weld on mounts from Redwood on target fabrication in Redwood Pk Adelaide 04098 45800. There are some photos of my conversion here http://www.gmh-toran...oject-begins/ They supplyed the crossmember for my T400 as well.
Easy job if you are fair with a good mig
Posted 03 October 2020 - 04:15 PM
Thank you all think I have it sorted appreciate your time and help
