Whats a healthy compression ratio for an LJ XU1 with standard engine unknown cam (lumpy). Just ordered a tester and want to know what the PSI should be. Can't seem to get a straight answer on google as some say depends on the cam overlap whatever that means?
Compression test
Posted 06 October 2020 - 08:01 PM
Posted 06 October 2020 - 09:20 PM
A cam with a wide lobe centre angle will generate more compression than one with a tight centre angle due to lesser overlap. Since you don't know what cam you have this point is academic. The main thing is that compressions vary by a minimal amount between cylinders, say no more than 10%. Pull all six plugs with the engine warm and check compressions with the throttle blades open. At a guess I would expect between 140 and 170 psi. Also have your battery fully charged so that cranking speed is consistant between cylinders.
Edited by V-SLR5000-P, 06 October 2020 - 09:23 PM.
Posted 06 October 2020 - 09:40 PM
The actual dynamic compression reading that you’ll see on the gauge will absolutely depend on your specific combination. The static compression ratio and cam specs clearly having a big influence.
I just went through this myself on my 383 SBC with 10.5 comp and mild cam - the comp test produced a nice healthy 190PSI across all 8 cylinders.
There must be plenty of people with XU1’s or similar hot 6’s that can share typical readings from that kind of combo.
Posted 07 October 2020 - 07:14 AM
Posted 07 October 2020 - 04:19 PM
Another silly question,do the holden red engine heads including XU1 have valve stem seals?
Posted 04 November 2020 - 04:39 PM
This is not actually correct, but is an extremely common misconception- the overlap does not determine the compression/ psi that the engine sees on a comp test...
The inlet valve closing angle and static compression ratio, as well as general ring seal, determine what reading you will get.
A 110lsa cam with 240 degrees duration, installed with 4 degrees advance will have LESS cranking compression than a cam with 106lsa and 240 degrees duration, again installed with 4 degrees advance.
The wider LSA will close the inlet valve later in the cycle than the same duration cam on a smaller LSA- the later closing inlet valve bleeds off the compression before it can be built in the cylinder, hence reducing the cranking compression reading.
Hence, if you are running a compression limited setup, say a head / piston/bore combo that makes 9.5:1 compression, you can tighten the LSA to regain some cranking cylinder pressure (but cranking comp is a somewhat arbitrary number anyway). The tighter LSA cam will have more overlap but this is simply not what bleeds off the compression on a comp gauge.
Edited by LC-GTR-1969, 04 November 2020 - 04:41 PM.
Posted 04 November 2020 - 10:01 PM
Just to add a little, if your doing it for engine health, it is a good method, easy to do but a leak down tester is better again, this can be used to check if its valves, rings or head gasket that is losing pressure.
