Disc Brake Master Cylinder
Posted 15 October 2020 - 07:16 PM
Posted 15 October 2020 - 08:00 PM
No you must have those tapered brass seats in there. They are what the double flares on the brake pipes seal against.
You can see the ring marks where the tube flares have previously bedded into the soft brass to form a leak proof seal.
Edited by S pack, 15 October 2020 - 08:01 PM.
Posted 15 October 2020 - 08:02 PM
The brass olives are what the pipes seal on
Stick a paperclip down the holes
If there's resistance in the larger hole.(rear brakes) .. good... if its in the smaller hole... maybe not so good (there could be a disc valve in it though)
Posted 15 October 2020 - 08:08 PM
Edited by Indy Orange, 15 October 2020 - 08:17 PM.
Posted 15 October 2020 - 08:34 PM
No, as Neil advised, gently push a paper clip into the hole in the seat. There should be a check valve in the rear port which will cause an obstruction to the paper clip.
When you push the paper clip into the front port seat there should be nothing in the way allowing the paper clip to slide right in without restriction until you possibly hit the cylinder piston cups.
Posted 15 October 2020 - 08:59 PM
