UC camber caster
3 replies to this topic
#1 sgo90
sgo90
  • 17 posts
Posted 17 October 2020 - 03:28 PM
So a UC front end needs all the shims removed to get to zero camber.
At this point will there be any caster inheret in the set up or will it be around zero too?
#2 76lxhatch
  • 7,215 posts
Posted 18 October 2020 - 06:35 AM
There should be a little positive caster if you have the correct control arms, the top ball joint is offset rearward to achieve this. Ideally you'd want a bit more though (not that zero camber is much good either).
#3 sgo90
sgo90
  • 17 posts
Posted 18 October 2020 - 01:01 PM
Thanks, that makes sense.
#4 axistr
axistr
  • 1,222 posts
Posted 18 October 2020 - 01:18 PM
If your using it for regular track work add lots of positive caster and a reasonably amount of negative camber. If its for street use stand the tyres up. Setting more than 1/2 deg negative static with the correct toe setting will give you inner tyre ware.
