Have any of you guys had much experience with rear spring rate in a torana hatch? Not going to be circuit raced it’s a street car but the odd 1/4 here and there.
Front end is coil over and are 400lb still yet to test how this will go.
As for the rear I am doing a custom spring and shock setup.
Have read lowered lovells are aroun 600-700lb 🤷♂️
I want a firm but not too firm spring.
120ltr drop tank most likely won’t see many back seat passengers.
Thanks in advance
LX TORANA REAR SPRING RATE
MRGMH
, Nov 03 2020 09:58 PM
1 reply to this topic
Posted 03 November 2020 - 09:58 PM
Posted 04 November 2020 - 10:06 PM
Lovells rear springs are about 250-280pds, sure closer to 250.
Front end lovells are 700-750 pounds.
These are are a reasonable starting point for road use.
Using them and a good shock(bilstein), 27mm front sway bar, Small rear bar will make it a nice car to drive.
