LC GTR Gearbox crossmember
11 replies to this topic
#1 Flaming Skull 57
Flaming Skull 57
  • 54 posts
  • Name:John Harris
  • Car:LC Torana
Posted 19 November 2020 - 05:12 PM
Hi All
I have a LC GTR Torana 4 speed and I'm putting it back together and bolting up the rear gearbox member. The issue I'm having is it could bolt up in two places. I mean if I push it forward it will fit into one set of holes but if I pull it back it will fit into the back holes. There are several positions I can bolt the cross member to but which is the right one? If I use the back holes it looks like I would need a spacer between the cross member and the chassis. Any ideas?
Cheers John
#2 S pack
  • 13,341 posts
Posted 19 November 2020 - 05:21 PM
Opel 4spd or Aussie M20 4spd?
#3 Flaming Skull 57
Flaming Skull 57
  • 54 posts
  • Name:John Harris
  • Car:LC Torana
Posted 19 November 2020 - 05:41 PM
Aussie 4 Speed
#4 S pack
  • 13,341 posts
Posted 19 November 2020 - 05:49 PM
If it is an LC and 1972 LJ gearbox crossmember do you have the spacers that go between the member and the chassis rails?
#5 Flaming Skull 57
Flaming Skull 57
  • 54 posts
  • Name:John Harris
  • Car:LC Torana
Posted 19 November 2020 - 06:28 PM
It an LC 1971 and after all this time I can't remember if there were spacers
#6 S pack
  • 13,341 posts
Posted 19 November 2020 - 07:27 PM
See post #63. http://www.gmh-toran...s-member/page-3
#7 Flaming Skull 57
Flaming Skull 57
  • 54 posts
  • Name:John Harris
  • Car:LC Torana
Posted 20 November 2020 - 04:43 PM
Thanks Dave. I've got the spacers. Which are the correct holes to bolt the cross member into. There are seven. Some are obviously wrong   but I have  two bolt hole options.
 If I use the forward option that leaves the back two holes exposed.
If I use the back hole option it leaves only one bolt hole exposed
What I mean is if I use the front holes the engine is  closer to the radiator. Perhaps someone can tell me what is the distance of the fan from the radiator in a GTR manual. Cheers
#8 S pack
  • 13,341 posts
Posted 20 November 2020 - 05:36 PM
John, the position of the engine sitting correctly on it's mounts will dictate the position of the gearbox crossmember.
For reference here is a 1972 LJ with Aussie M20.
Attached File  LJ Aussie M20 crossmember mounting.jpg   200.33K   5 downloads
#9 Flaming Skull 57
Flaming Skull 57
  • 54 posts
  • Name:John Harris
  • Car:LC Torana
Posted 20 November 2020 - 06:10 PM
Thanks Dave.  A picture speaks a thousand words.. Much Appreciated Cheers John
#10 Flaming Skull 57
Flaming Skull 57
  • 54 posts
  • Name:John Harris
  • Car:LC Torana
Posted 20 November 2020 - 06:23 PM
There is  a bit of a difference where the crossmember bolts up onto the chassis( a gap at the rear ) where the two channels coming together. should I put a washer there or just bolt it up on the angle.
#11 S pack
  • 13,341 posts
Posted 20 November 2020 - 06:54 PM
Just bolt it up with the spacers between the rails and the crossmember. That is how they were built.
#12 grumpy xu1
grumpy xu1
  • 2,389 posts
  • Name:Gary
  • Car:lj xu1
Posted 20 November 2020 - 09:25 PM
If you follow what Dave stated here, literally it can only go in the correct place. The spacers out on the bottom of the chassis are 1/4" thick to.
