I have just finished fitting aircon in my LJ Rally car. It was a mission to find a unit that looked factory fitted but I think the end result is ok. The install needs 2 holes through the fire wall (for hoses) but otherwise uses existing holes. If you would like some pics let me know
LJ Air Conditioning
#1 _DrBill_
Posted 26 November 2020 - 10:14 PM
Posted 26 November 2020 - 10:41 PM
Posted 27 November 2020 - 06:26 AM
Posted 27 November 2020 - 06:56 AM
There was no factory-fitted or factory option air conditioning for LJ Toranas.
The closest thing would be the Smiths custom under dash unit which was offered as a dealer fitted accessory.
I have a similar unit (made by Mark IV) in my LJ.
Dr Terry
Posted 27 November 2020 - 07:14 PM
#6 _DrBill_
Posted 11 December 2020 - 04:15 PM
Used right hand side switch binnacle on left, put a AFR gauge in column hole.
Ducting lives behind binnacle, centre vents have maximum flow, vents in binnacle have reduced flow so as not to freeze the passenger.
All parts from Auto Aer, universal condenser, receiver drier, and 2100 btu under dash unit.
Used Auto Aer Holden 6 compressor bracket, modified to take the Sanden compact compressor. Currently running the Auto Aer front pulley but feel it overdrives the compressor (too fast at race speeds, perfect for around town). Will turn up a smaller diameter front pulley in the near future.
14 Degrees at the vents on a 35 degree day, slight decrease in engine coolant temp secondary to the condenser electric fan.
I am going to do another binnacle and move the standard heater/vent controls to the left binnacle and fit a vent in the right binnacle where the heater/vent controls were.
