Holden Harmonic Balancer / timing cover seal
6 replies to this topic
#1 Kevin75
Kevin75
  • 5 posts
  • Name:Kevin
  • Car:LX
Posted 30 November 2020 - 07:01 PM
Gday everyone,
Quick question, I've just purchased a New Harmonic Balancer and timing cover seal, do I need to lubricate this or apply anything (either side) when installing,
Cheers and thanks
Kev
Attached File  IMG_19483666.jpg   109.84K   11 downloads
#2 S pack
  • 15,536 posts
Posted 30 November 2020 - 08:26 PM
I always apply a smear of gasket goo around the outer surface of the new oil seal metal shell before installing into the timing cover and lightly lubricate the rubber seal and the seal surface on the balancer with engine oil prior to assembly.
#3 Bigfella237
  • 4,368 posts
Posted 30 November 2020 - 09:45 PM
And give the seal running surface on the balancer a good clean before fitting, they are quite often coated in gunk that stops them going rusty while sitting in a warehouse.
P.S. Very pretty but it's gonna run like a busted arse with that single carby setup!
Edited by Bigfella237, 30 November 2020 - 09:45 PM.
#4 I'm a Red Motor fiend
  • 758 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 01 December 2020 - 12:29 PM
Nice.... What are your engine specs?
#5 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 01 December 2020 - 05:38 PM
3 bond number 1 on the outside of the shell, either some rubber grease or engine oil, for fitment of the cleaned balancer, is my method.
#6 Kevin75
Kevin75
  • 5 posts
  • Name:Kevin
  • Car:LX
Posted 01 December 2020 - 06:15 PM
Gday there,
I bought motor a few years back and has sat in my shed for quite a while, but when i got it basic details are
Yellow Terra head
Roller rockers
screw in studs
2" SU's
Straight cut gears
40/80 cam
Hi Vol oil pump,
I had it stripped down a while back and re - honed with new rings & bearings, and am just getting all the extra bits on it now as my Spray painter has promised to have the shell back to me in Feb
#7 liswar2
liswar2
  • 1,480 posts
  • Name:Wazza
Posted 01 December 2020 - 10:51 PM
Is that a coffee stain on the carpet in the lounge ?
Or did the motor take a leak ,
Just kidding
Good place to do a reassemble.
