Holden 308 fresh rebuild
6 replies to this topic
#1 kavesh
kavesh
  • 72 posts
  • Name:Kavesh Maharaj
  • Car:1971 Holden UTE (Chev El Camino - RSA)
Posted 12 December 2020 - 04:07 AM
Hi guys
I have assembled my stock 308 motor and ready to fire her up.
What is the preferred start up procedure on a fresh 308, crank the motor with plugs out or just fire it up.
I have stuffed vaseline in the oil pump and have filled the oil filter with oil. I am using a monograde oil for the first run in period.
Would appreciate any advice on the start up please
#2 warrenm
warrenm
  • 2,107 posts
  • Car:1972 LJ Torana
Posted 12 December 2020 - 05:39 AM
Take the plugs out & crank until you have oil pressure, then fit the plugs & fire it up.
#3 yel327
  • 13,085 posts
Posted 12 December 2020 - 07:40 AM
I assume you have cam lube on the cam lobes and lifter bases?
#4 rexy
rexy
  • 3,588 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 12 December 2020 - 07:04 PM
Just like Warren said above.
#5 Bigfella237
  • 4,373 posts
Posted 12 December 2020 - 08:18 PM
The absolute best way is to use an oil accumulator and have full oil pressure up before the engine cranks at all. But failing that, see above.
#6 _jakeslxss_
_jakeslxss_
Posted 21 December 2020 - 10:52 PM
how long does it usually take to build up oil pressure by cranking it over? ive just built a stroker and cranked it over today for the first time. i was doing it for approximately 5-10 seconds at a time and still didnt see any pressure on a gauge setup  next to the pressure switch.
does it usually take longer than 5-10 seconds or should i look into it further?
Edited by jakeslxss, 21 December 2020 - 10:54 PM.
#7 rexy
rexy
  • 3,588 posts
  • Name:Rexy
Posted 21 December 2020 - 11:00 PM
If it’s a dry rebuild then it may take quite some time.
it took more than a minute to see pressure on a mechanical gauge in my 383 after an engine swap that included changing sump and pickup. Was nearly instantaneous in the SBC and BBC when I did the same.
