LC 82911 Door Trim Stainless Retainers - Alternatives
7 replies to this topic
#1 ljv8
ljv8
  • 299 posts
  • Name:Steve
  • Car:LC GTR
Posted 17 December 2020 - 09:29 PM
I'm resided to the fact that I will probably never get my hands on a set of LC 82911 door trim / rear trim stainless steel retainers.  The odd one turns up on eBay now and then and goes for a ridiculous amount of money, due to the old supply and demand issue.
I know the complexity of the bends of the front and back retainer trims have prevented these being re-produced to date, probably also the fact that there is a very limited market of LC GTR's and XU1's still needing these.
It looks a little incomplete and a little ugly without the stainless trims as below.
Attached File  no trim 01.png   388.09K   4 downloads
Attached File  no trim 02.png   387.46K   3 downloads
Has anyone come up with an alternative solution, even if it's only cosmetic?  They seem to sit okay without the retainers.
Was searching for a chrome u channel trim and found this example.  It will be of course only cosmetic and not screw to the door and hold the trim in place.  It might look okay-ish if I can find a compatible size.
https://www.carbuild...-55mm-per-metre
Does anyone know how many mm of stainless trim hangs over the door card trim?  I'm guessing it's about 8 or so mm.
Attached File  trim example.png   370.9K   1 downloads
#2 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 17 December 2020 - 09:42 PM
Pretty sure a guy on FB was reproducing these a while back. He was still asking a fair bit but better than scrounging for second hand.
#3 limo
limo
  • 2,672 posts
Posted 18 December 2020 - 08:31 PM
I know some one who used Ford pieces on a XU1 clone. Not the same length, similar shape. Looks OK.
#4 S pack
  • 15,538 posts
Posted 18 December 2020 - 08:51 PM
Yikes :o https://www.ebay.com...AyABEgL4BPD_BwE
#5 sibhs
sibhs
  • 2,702 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 18 December 2020 - 08:55 PM
FaceB Tim Pollock  0400 382 095  he made some.
#6 MictheAussie
MictheAussie
  • 234 posts
  • Name:Mic
  • Car:LJ
Posted 19 December 2020 - 02:53 AM
Remember when you could get a whole LC GTR for this price?
#7 ljv8
ljv8
  • 299 posts
  • Name:Steve
  • Car:LC GTR
Posted 19 December 2020 - 08:18 AM
Hey thanks guy's, yeah I saw that too Dave, not sure if it's the same seller but there is one set for $2500 on Facebook.  That is only a few hundred bucks under what I paid for the whole car in 2001 Mic!
Ok will reach out to Tim thanks Marty will see what the damage is.
Hey Limo I do recall now that you mention it hearing about an early Ford having similar trims.  I will need to do some searching to find out what model, and maybe if it's more common will be a few thousand dollars less.
#8 ljv8
ljv8
  • 299 posts
  • Name:Steve
  • Car:LC GTR
Posted 19 December 2020 - 08:34 AM
Ok yeah XW-XY door trim tops.  Look very similar, geez the Ford guy's are looked after with reproduction stuff $100 a set.  What a bargain.
https://allmusclecar...moulds-4pc.html
From reading another post they are slightly short for front door.  If I can't get a reproduction LC set, for around $100 will give the XY one's a go.  Just don't tell anyone.  Well it's not really a Ford produced part it's a reproduction  :D.
