Water pump identification
Water Pump
8 replies to this topic
#1 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,289 posts
  • Car:ɐuɐɹoʇ
Posted 21 December 2020 - 07:38 PM
Hi all
About 10 years ago I bought a NOS Holden water-pump (cast iron impeller). It came in an original Holden box with P/N 92008365 printed on the outside. According to the box, it suited among other vehicles, LJ 6 cylinder cars. I test fitted it and it came up short (no pun intended). It was about 2mm short of the hole in the fan. Further research reveals that 92008365 is the correct part number but it should have 10mm of the shaft forward of the pulley/fan mounting flange (this one has 7.5mm). It appears to have been put in the wrong packaging. Being too short, I don't feel inclined to use it but am nonetheless interested in what was its intended application. I should say it mounts up correctly in terms of pulley size and hole pattern.
Any ideas?
Bazza
  • Attached File  Fan.jpg   53.08K   6 downloads
#2 crabba67
crabba67
  • 903 posts
  • Name:anthony
Posted 21 December 2020 - 07:57 PM
That’s the difference
#3 S pack
  • 15,538 posts
Posted 21 December 2020 - 08:13 PM
Here Bazza.
Attached File  P1020533 resize.jpg   277.09K   6 downloads
#4 rodomo
  • 17,998 posts
Posted 21 December 2020 - 09:30 PM
Don't use it. The shaft is the spigot for the fan. The bolts alone wont hold it at 6500rpm
#5 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 22 December 2020 - 06:25 PM
Just press it apart, get a longer shaft made, put it back together & you're done. Technically it's the spring washers that will hold the fan on, the shaft pretty much just becomes a locating dowel. Not that it's not important. A good machine shop could make you 1 Baz.
#6 rodomo
  • 17,998 posts
Posted 22 December 2020 - 10:01 PM
That is bad info on something that rotates. Flywheels are spigoted as are clutches (dowel bolts).
#7 ljv8
ljv8
  • 299 posts
  • Name:Steve
  • Car:LC GTR
Posted 25 December 2020 - 04:03 PM
Hi Bazza
I have the same water pump on my LC GTR.  I found the same thing I had an LJ fan I thought I could use but the nose is too short.  You have to use a LC GTR type fan with this water pump.  The GTR fan has a flat face where it bolts up, so  the short snout pokes through perfectly.  I'm guessing this fan blade wasn't just fitted to the GTR though.
  • Attached File  fan.jpg   103.71K   3 downloads
#8 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,289 posts
  • Car:ɐuɐɹoʇ
Posted 25 December 2020 - 10:32 PM
Thanks- all has become much clearer.
Bazza
#9 VIXL34s
VIXL34s
  • 177 posts
  • Name:jeff
  • Car:2x L34s,+ HZ GTS, A9X HATCH.A9X SEDAN
Posted 26 December 2020 - 08:56 AM
Can you not end for end the bearing assembly.
Also tagged with one or more of these keywords: Water Pump
