G'day,
Doing the engine bay panel work on my LJ and just wanting a little help.
I'm doing the inner skirt panels and I have some gaps. I've attached a few photos and you can see where the front end suspension bolts on there's a few mm gap, and it seems to be a couple mm to far forward as its poking the chassis rail fold at the end but it seems to be as far back as I can get it.
Can I pull these in with tec screws and the spot weld? or should I try persuading the panels to get closer with a hammer?
These panels were brand new but were put on by 1 panel beater and cut off (roughly) by another.
Also are there measurements I can go off to make sure I have these panels sitting at the right level on the chassis rail? Or is it something I check with more panels on?
Thanks!
