LS2 Conversion
2 replies to this topic
#1 Mid-life Crisis
Mid-life Crisis
  • 94 posts
  • Name:David Lovett
  • Car:LX Hatchback
Posted 24 December 2020 - 05:38 PM
Question for the Gurus
I am going to update my Hatch to an LS2 Manual and was wondering if the computer is impacted dependant on Manual or Auto. So do I need to buy an LS2 with computer that all came out of a Manual, or does it matter if it was attached to an auto???
Over to you
#2 Bigfella237
  • 4,369 posts
Posted 25 December 2020 - 12:17 PM
It's been a while since I played with OEM computers however I *think* the PCMs are the same but the 'tunes' are different. And yes, they are electronic autos so controlled by the PCM.
I wouldn't bother with the OEM stuff myself, there's too much bloat in them and everything expects to be connected to everything else and has a conniption when it isn't.
It's a bit more expensive to go after-market ECU initially but might save you some headaches later on?
#3 Rockoz
Rockoz
  • 3,961 posts
  • Name:Rob
Posted 25 December 2020 - 06:16 PM
Yep.
Computers are the same.
I did read though that going manual it is easier if you choose non electronic auto in the menu.
Apparently then the expected inputs from a manual such as clutch are ignored.
Im in the process of setting up a tuning tool and will be connecting the 2 ECUs I have to it to have a play.
So will know more in the near future hopefully.
Rob
