Hi all. I have a reco WB dual booster and P7953 master cylinder. I have stuffed up and had the lines double flared and whilst the front lines seem to seat ok the rear line fitting bottoms out before the flare seats.
My question is can I buy a replacement master cylinder that will take double flared lines and will bolt straight up? Wilwood seem to have a few options but I'm no expert and not sure if these are direct replacements. I understand that this may be costly but, the alternative is pulling out the lines and remaking them which I am obviously trying to avoid
Is there an adapter that would bolt up to the master and take the double flares?
Are there any other "quick fixes. No way I can re-flare the lines as they sit and I'm not sure if they should be single or bubble flare. Since that photo was taken the engine and all bolt-ons have been assembled.
Help and thanks as always. Cheers Ron
