Stone tray fasteners
14 replies to this topic
#1 jd lj
jd lj
  • 2,100 posts
  • Name:James D
  • Car:LJ SVO
Posted 05 January 2021 - 01:39 PM
I'm just chasing confirmation on what fasteners were used to secure the front of the stone tray to the body. A friend mentioned that a "U" nut was fitted to the stone tray and then a bolt (probably about a 5/16 at a guess) goes through the bodywork and into the "U" nut, is this correct?
I had a look through the parts catalogue but couldn't find anything, that doesn't mean that it's not there but I couldn't find the stone tray in the catalogue at all.
James
#2 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 05 January 2021 - 02:26 PM
Like these?
#3 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,289 posts
  • Car:ɐuɐɹoʇ
Posted 05 January 2021 - 03:09 PM
Hi
Splash Guard (don't know why people call them stone guards?) and J Nuts
Bazza
#4 jd lj
jd lj
  • 2,100 posts
  • Name:James D
  • Car:LJ SVO
Posted 05 January 2021 - 04:25 PM
Thanks Bazza, great work.
Now to find a supplier, that shouldn't be too hard though.
#5 jd lj
jd lj
  • 2,100 posts
  • Name:James D
  • Car:LJ SVO
Posted 05 January 2021 - 04:54 PM
I found two suppliers in Australia however the length is longer than the original, atleast on tge website with the overall dimensions.
https://nhtb.com.au/...ts-captive-nuts
https://www.jnsfaste...t-bsw-un-qpp-10
#6 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 06 January 2021 - 12:04 PM
If anyone has some of the screws pictured in the j nut that they will sell, i would be happy to buy them, Gary.
#7 stealthxu1
stealthxu1
  • 344 posts
  • Name:Stealth
  • Car:lc 2 door project
Posted 09 January 2021 - 09:11 AM
Ebay 322988161972
#8 rodomo
  • 17,999 posts
Posted 09 January 2021 - 10:32 PM
https://www.ebay.com...61972&_sacat=0
#9 jd lj
jd lj
  • 2,100 posts
  • Name:James D
  • Car:LJ SVO
Posted 10 January 2021 - 06:55 AM
That makes it easy but an expensive way to get the bits. For $10 from my link above and a couple more dollars at the local fasteners shop you'd have yourself a kit.
#10 yel327
  • 13,085 posts
Posted 10 January 2021 - 08:00 AM
Hi
Bazza
What is the body screw used for? I had to go to the USA to source the body screws used to hold the rear of the heat shield above a HK GTS muffler. They are a US GM part number. Little different to that one in the image but same type of thing.
#11 RallyRed
  • 7,841 posts
Posted 10 January 2021 - 08:57 AM
Interesting, that Barn Find pic......
I had a funny feeling that the 2 screws each side that hold the splash tray to the underside of the chassis rails, were more of a self tapper type screw?, ( as per Bazza's pic ) due to the rail not being thick enough to get a real thread cut in it?
( I always call it a stone tray too, but have since learnt that the stone tray is actually the panel that runs parallel to the bumper)
Regardless, I just fit Nutserts in there now anyway, get a good secure fitting, and rivet counters cannot tell as they are hidden by the return flange of the tray anyway.
Edited by RallyRed, 10 January 2021 - 09:02 AM.
#12 S pack
  • 15,539 posts
Posted 10 January 2021 - 09:38 AM
For the rivet counters, the  'J' nut bolts offered by Barn Find Spares are not exactly the same as the originals.
Attached File  Splash Guard Bolt 01.jpg   92.39K   6 downloads
Attached File  Splash Guard Bolt 02.jpg   93.35K   4 downloads
Edited by S pack, 10 January 2021 - 09:39 AM.
#13 RallyRed
  • 7,841 posts
Posted 10 January 2021 - 11:57 AM
Thought so. Ta Dave
#14 piquet
piquet
  • 856 posts
Posted 22 February 2021 - 09:29 PM
As my stone tray has to come out often I replaced the hex had self tappers screws with rivnuts/nutserts.
#15 S pack
  • 15,539 posts
Posted 22 February 2021 - 09:43 PM
Recently bought a nutsert tool kit to do mine.
