Speedo drive seal.
9 replies to this topic
#1 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 23 January 2021 - 12:03 PM
Hi guys, I have a new speedo drive with a new a new seal I wanted to fit, but I can't see how on earth I'd get it on ,there's no way known to man that suckers going to go over that connection ,I've tried everything ,hot water ,dish washing liquid ,no go.
Looks like the original speedo casing would have come with the seal pre fitted.Do I have to get the crimped end off? Any advise welcomed ,Ta Paul.
#2 S pack
  • 15,539 posts
Posted 23 January 2021 - 04:10 PM
I have heard of cutting the grommet across the shortest section, put it over the cable and superglue it together again. How long it will last I do not know.
#3 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 23 January 2021 - 04:28 PM
Use either loctite 406 or sikaflex if you do cut the rubber.
#4 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 23 January 2021 - 07:27 PM
Ok thanks .
#5 claysummers
claysummers
  • 3,333 posts
  • Name:Clay
Posted 23 January 2021 - 09:36 PM
Just cut it at 45degrees to the firewall plane. Orientate the grommet so the cut is hidden by the cable. It won't be noticed, and you won't need to glue it. Yes the original were put on prior to crimping ends.
#6 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 24 January 2021 - 11:25 AM
Thankyou gents,I'll cut and glue
#7 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 26 January 2021 - 06:34 PM
Thanks fellas , cutting and glueing worked well.
#8 S pack
  • 15,539 posts
Posted 26 January 2021 - 09:28 PM
:clap:
#9 sibhs
sibhs
  • 2,703 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 26 January 2021 - 09:53 PM
Hi Paul, this is how I got my rubber on.
http://www.gmh-toran...ommet/?p=851083
#10 Indy Orange
Indy Orange
  • 2,848 posts
  • Name:Paul
Posted 27 January 2021 - 10:24 AM
Thanks Marty , I did try with the hot water trick and dishwashing liquid , very difficult ,the cutting method worked well , you can’t see it and won’t pull apart.
