Clutch thrust bearing in LX
5 replies to this topic
#1 Swarbs
Swarbs
  • 1,662 posts
  • Car:LX 5000
Posted 24 January 2021 - 06:22 PM
Just wondering if anyone has come across this before
Mc Cloud clutch - new bearing and Super T10 box
The prob i have is when the box is installed the thrust bearing at the rear end is against the input cover plate of the box
The front end is pushing against the fingers of the pressure plate
Only by about 2 - 3 mm but i was hoping for that in bearing free play while the clutch is disengaged
Plate is installed correctly
The only way out of this i can see is to source a "shorter" thrust bearing
Is there such a beastie Prob would need at least 6mm to take out the pressure it is putting on the fingers and also give me a bit of free play
#2 rexy
rexy
  • 3,584 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 25 January 2021 - 09:46 AM
You used to be able to get the proper metal bearing carriers in all different heights. Maybe start with a call to Mal Wood or CRS/Waddingtons?
If you have a friend with a lathe they might be able to modify yours?
#3 Dr Terry
Dr Terry
  • 3,276 posts
Posted 25 January 2021 - 09:51 AM
You need the 'short' GM clutch release bearing.These are the same type used for Saginaws & Muncies behind V8s in HK/HT/HG/HQ.
The 2 part numbers I have are BRG2081 (Exedy) or TB34003 (Clutch Pro).
Dr Terry
#4 76lxhatch
  • 7,150 posts
Posted 25 January 2021 - 09:56 AM
^ That's most likely correct, but just looking at the line on the carrier - is the bearing pressed all the way on?
#5 Dr Terry
Dr Terry
  • 3,276 posts
Posted 25 January 2021 - 10:10 AM
The centre part is not pressed in, it an integral part of the bearing itself, unlike many imports where the bearing is a separate item, pressed on to a carrier.
Dr Terry
#6 76lxhatch
  • 7,150 posts
Posted 25 January 2021 - 11:54 AM
Some of the early ones I've seen are definitely pressed on, but come to think of it a lot are integrated like you say too
