LH steering Arms ?
9 replies to this topic
#1 UCSLE
UCSLE
  • 702 posts
  • Name:troy
  • Car:Goggomobil
Posted 10 February 2021 - 11:56 AM
anyone know what LH steering arms are made of ?
looking at cutting and welding them
I am thinking that they are cast steel but not sure
#2 Dr Terry
Dr Terry
  • 3,276 posts
Posted 10 February 2021 - 12:49 PM
They are forged steel.
AFAIK it is not legal to weld them.
Dr Terry
#3 ReplicarSLR
ReplicarSLR
  • 517 posts
  • Car:Not anymore unfortunately
Posted 10 February 2021 - 04:35 PM
Firstly why are you cutting and welding them? And as the good Dr said you are not allowed to weld them or heat and bend them on a street registered vehicle anyway.
#4 Heath
  • 18,307 posts
Posted 11 February 2021 - 10:13 AM
In the drift world it's very common to cut and shut steering arms (they call them 'knuckles' typically) on strut and double wishbone Japanese cars with very good results, but it's not a very accessible welding process, so only a few people/shops are confident enough to do them. Useful for changing steering ratios (and consequently maximum available lock), ackerman angles, etc.
Certainly illegal for road use - like welding on a steering column. Once done correctly there seems to be nothing wrong with the structure. Cars will hit walls and tear all of the suspension out of the subframes without bending or breaking the cut-and-shut steering arms. I assume they are made of the same materials? Although I actually had assumed they were cast steel also, and could be wrong.
Edited by Heath, 11 February 2021 - 10:14 AM.
#5 UCSLE
UCSLE
  • 702 posts
  • Name:troy
  • Car:Goggomobil
Posted 11 February 2021 - 12:14 PM
thanks for the reply's
the car wont be used on the road but still need it to be safe
the reason about cutting them was that i have some camaro stubs that I,m deciding to use but the holes for the arms are a little bit further apart
if they are forged steel that idea will get thrown in the too hard basket
Attached File  camstub.JPG   42.95K   4 downloads
#6 neglectedtorana
neglectedtorana
  • 965 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 11 February 2021 - 12:46 PM
Interesting, are the Camaro stubs dropped? Same kpi?
What benefits?
What about Camaro steering arms?
#7 76lxhatch
  • 7,150 posts
Posted 11 February 2021 - 02:57 PM
If it doesn't need to be road legal I'd be looking to make some new ones to suit, will be a lot easier to get everything exactly where you want it by machining holes rather than trying to line up welded pieces
#8 UCSLE
UCSLE
  • 702 posts
  • Name:troy
  • Car:Goggomobil
Posted 13 February 2021 - 10:33 AM
What benefits?
 same 9° Kpi but the downside is they are 15mm shorter (can be fixed with longer top balljoint )  and give about 8mm wider track each side
no real benefits they where cheap when i got them , thought i would give them a try
camaro arms look longer and the tie rod bolts from the bottom
Edited by UCSLE, 13 February 2021 - 10:33 AM.
#9 Bigfella237
  • 4,368 posts
Posted 13 February 2021 - 11:35 AM
An easy way to tell if something is steel or iron is to touch it with an angle grinder, if you get sparks then it's most likely steel as cast iron just gives off a kind of black powder.
#10 axistr
axistr
  • 1,169 posts
Posted 14 February 2021 - 08:51 AM
Yep as Bigfella said hit it with a grinder and watch the sparks. An old bloke once showed me the difference between the sparks. Steel gives off sparks that are in short straight lines, iron gives off sparks in crosses. Try it some time it still freaks me out a bit.
