Hi there, my Droptank has a sender (190 to 0 ohm) that is not compatible with the standard UC fuel gauge. The fuel gauge requires a sender that reads 282 ohm when empty, and 40 ohm when full. I can’t find a sender with the required ohms... Any suggestions?
The closest for sale is a 240 to 30 ohm sender, could I use it, will it be accurate enough? Any tips/ tricks I can try? All help is appreciated. Cheers Paul.
