Rear Salisbury disc park brake adjustment
6 replies to this topic
#1 Swarbs
Swarbs
  • 1,662 posts
  • Car:LX 5000
Posted 28 February 2021 - 04:52 PM
Hi
Just looking at setting the park brake adjustment
LX and it has been converted to a Salisbury rear end with what i presume is a Statesman disc set up
I have refurbished the calipers a long time ago so all good there
I cannot for the life of me find any info on setting these up apart from a Dave Mc post about doing an A9X
Said you could do it with a pair of pointy nose pliers was about all i got out of it
The brake calipers have not been bled yet (just for info)
I have this arrangement
Attached File  WIN_20210228_14_33_41_Pro.jpg   153.57K   5 downloads
Any help with how to sort appreciated
#2 Kevrev
Kevrev
  • 409 posts
  • Name:Kevin
  • Car:73 LJ GTR, 77 LX SS 253 Manual
Posted 28 February 2021 - 07:06 PM
Hi Dave,
Some light reading for you...
Cheers Kev
Edited by Kevrev, 28 February 2021 - 07:08 PM.
#3 dattoman
  • 16,471 posts
Posted 28 February 2021 - 11:06 PM
Put the caliper back together first
The adjusting while it can be done from the back...is actually done with piston...pad side
Adjustment is not done by handbrake lever either
All those calipers are adjusted same way...all Holden and Ford variants
#4 Swarbs
Swarbs
  • 1,662 posts
  • Car:LX 5000
Posted 01 March 2021 - 04:37 PM
Thanks Kev
Jackpot
When you say piston side Neil
The caliper comes off the disc to get at this adjustment yes?
All is back together
I take it looking at the diagram Kev supplied above
With the nut adjuster being inside the piston i have to push the piston toward the adjuster screw while rotating it so the thread engages?
The above commentary doesn't seem to cover this
or i have missed something
Edited by Swarbs, 01 March 2021 - 04:38 PM.
#5 dattoman
  • 16,471 posts
Posted 01 March 2021 - 06:31 PM
Yes mate...pads in. caliper on...caliper off pads out.. adjust.. repeat
#6 Swarbs
Swarbs
  • 1,662 posts
  • Car:LX 5000
Posted 03 March 2021 - 09:59 AM
Sorted
Thanks Kev and Neil
Forum comes through with the goods yet again   :spoton:
Just for posterity's sake thread was already engaged and it was basically an adjustment with rotating the piston
#7 Dr Terry
Dr Terry
  • 3,276 posts
Posted 06 March 2021 - 08:19 AM
There is no 'adjustment' as such with these callipers. The piston is only wound back in to allow new pads to be fitted & they 'self adjust' as the hydraulic pressure pushes the piston back out again.
Just fully assemble everything, bed the pads in & then adjust the slack out of the cable.
Dr Terry
