Superpro upper bushes
4 replies to this topic
#1 benno81
benno81
  • 709 posts
Posted 02 March 2021 - 05:06 PM
Just installed superpro bushes on uc upper control arms do they not fully seat in the holes?
#2 76lxhatch
  • 7,153 posts
Posted 02 March 2021 - 05:18 PM
Correct, the flange doesn't sit hard against the arm, it increases in diameter so it it won't go in any further just before that point (so there is a gap). It should make sense with the pivot in place, don't forget the inner washers if provided.
#3 benno81
benno81
  • 709 posts
Posted 03 March 2021 - 12:27 PM
Thanks i thought as much not sure what the story behind doing this is ?
#4 76lxhatch
  • 7,153 posts
Posted 04 March 2021 - 04:35 AM
I guess the original rubber ones have a bit more on the end (rubber engages on both surfaces and twists as a bushing, whereas polyurethane is greased and is actually a bearing) so this ensures correct placement/dimension with minimal material?
#5 ls2lxhatch
  • 5,332 posts
Posted 04 March 2021 - 10:02 PM
The factory rubber bushes do not press in all the way either due to the radius on the bush shell.
I am sure I have seen a service manual that specified the gap.
