Thanks mate,
the Harmonic balancer and alternator pulley are new and are machined steel. I had a 5m long laser line on all the H/B, water pump and alternator pulley and spun them by hand and couldnt see anything obvious. Idled the motor without belts on when cold with the laser and a timing light strobe on them and still couldnt see anything. So not that i can see with my eyes but still looking.
First time round set the belt tightness as i normally do just be feel on an already run in belt. Second time around Have only tensioned the belt as per the belt manufacturers specs and retentioned after run in, purchased a dayco krikit tension measuring device. After reading how the belt exerts force against the pulley i was going to try more tension but dont want to kill my water pump bearing. So will do soon but need to do a bit more checking first.
I doubled up the alternator top mount, so the top adjuster part is now 10mm thick. Its connected to the alternator, P/S solid bracket that connects to the block with three bolts as its a black motor. So i dont think so.
Does not roll the power steering belt at all, only the fan/alt belt. Although P/S belt much shorter and sits in the driving pulley flush and not riding out like the H/B pulley.
after i get it back together, ill try running it whle watching and put a strobe on it to see if i can see anything. Last time i did that it was dancing around everytime it received a shock and you can see the slack side of the pulleys double.
