Can anyone help me to identify if the LX Hatchback removable steering column panel at the Fire wall (see Picture) has a gasket. I cannot locate it in any parts lists I have. If it does have a Gasket... where can I buy one
Steering Column Panel at the Fire wall
Posted 27 March 2021 - 07:38 PM
Posted 27 March 2021 - 07:42 PM
Posted 27 March 2021 - 07:47 PM
From memory most I ever pulled apart be it Statesman, Holden or Torana just had black caulking compound in the join. I bought a tube from Bunnings to put the column back in my Hk. I’m using the same stuff to seal the tank to the body.
Agree, no gasket just caulking compound.
Posted 27 March 2021 - 07:48 PM
Anything specific, does it need to be Heat Resistant... orwould any silicone Sealant do???
Posted 27 March 2021 - 08:14 PM
https://www.bunnings...wE&gclsrc=aw.ds
Posted 27 March 2021 - 08:21 PM
Personally I wouldn't use silicone sealants.
Posted 27 March 2021 - 08:23 PM
I used this, not sure if perfectly correct but it works and comes apart years later if needed.
The D mastic would be perfect. I used Bostick black windscreen sealer which is similar.
