VL Power Steering Rack
18 replies to this topic
#1 hanra
  • 11,038 posts
Posted 29 March 2021 - 11:12 AM
Got a mate who is building a twin turbo 427 XB Falcon Sedan and he has what he believed was a VL steering rack. However he has found that the pinion is only splined half way around the shaft???
He has to try and mate that rack to the standard colum shift XB Falcon colum.
Is anyone familiar with this rack? Is it normal? From what I can tell its a VL Power Steering Rack????
#2 hanra
  • 11,038 posts
Posted 29 March 2021 - 11:27 AM
I did find these images from the VL workshop manual .
#3 hanra
  • 11,038 posts
Posted 29 March 2021 - 11:54 AM
Found this image of a VN Rack. Very similar.....
#4 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 29 March 2021 - 12:43 PM
VN & VL racks are the same aside from length...
Edited by UCgazman, 29 March 2021 - 12:44 PM.
#5 hanra
  • 11,038 posts
Posted 29 March 2021 - 12:47 PM
Ahhh righteo. Good to know.
#6 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
Posted 29 March 2021 - 12:49 PM
Actually I just remembered the mounting tabs are further apart on VN onwards too. Where it attaches to the column is definitely the same though.
#7 hanra
  • 11,038 posts
Posted 29 March 2021 - 03:17 PM
If anyone had that clamp that goes onto the pinion that would be handy!! I might have to join a commodore forum...... gahhhhhh.... Ill end up pulling the LSD out and putting a single spinner in...
#8 Dr Terry
Dr Terry
  • 3,350 posts
Posted 29 March 2021 - 05:30 PM
Not true.
They are essentially the same racks, with only one small difference. Same length, same mounts, same connections to pump. In fact the last 6 months of VL production used VN-style racks. VN front track is the same as VB-VL.
The only real difference is the location of the left/right pipes at the valve. They moved them to clear the right hand VN V6 exhaust pipe.
VP is the same rack again, with a different input shaft, which was square.
hanra, there should be enough VNs in wrecking yards for you to obtain a clamp.
Dr Terry
#9 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
Posted 29 March 2021 - 06:50 PM
You're right Dr Terry -
I had to check some old pics as I was sure I was right, turns out it was a VK I was thinking of - I had to cut off and move the k-frame brackets further out to fit a VN rack in it, as the mounts were different.
I'm was sure the front track was wider too, maybe thinking of VR? or I'm getting old - VN is definitely wider in the rear...
#10 Dr Terry
Dr Terry
  • 3,350 posts
Posted 30 March 2021 - 07:04 AM
Correct, the VB-VK was a TRW unit which had different mounts to the VL.
VL-VN-VP racks are the same length, but the VR-VS are longer due to the widened track on those models.
VN-VP have a wider rear track. Interestingly VR-VS have a wider rear track than VN-VP, but for sedan only. VR-VS wagons & utes still have the VN-VP rear track.
Dr Terry
#11 bat 53
bat 53
  • 524 posts
  • Name:albert
  • Car:lc gtr
Posted 30 March 2021 - 11:25 AM
vl has plastic hose connecting front to back vn on have metal
also vn-vs racks are same lenght steering arms are longer on vr vs also bigger dia
vn-vs is double D connection
vl rack head is differant angle
Edited by bat 53, 30 March 2021 - 11:26 AM.
#12 bat 53
bat 53
  • 524 posts
  • Name:albert
  • Car:lc gtr
Posted 30 March 2021 - 11:40 AM
sorry vp to vs are double D
#13 Dr Terry
Dr Terry
  • 3,350 posts
Posted 30 March 2021 - 03:19 PM
The plastic cross-over tube became steel 6 months before the end of VL production.
The VR-VS main shaft is also slightly longer (2 or 3mm from memory).
What do you mean by "double D" ?
The only "angle" that changed on the VL head was the position of the left/right tubes.
Dr Terry
#14 bat 53
bat 53
  • 524 posts
  • Name:albert
  • Car:lc gtr
Posted 30 March 2021 - 07:47 PM
the square on the head is knowen as a a double D
the head angle is about 1-2 degree differant
i found on my conversions that useing a vl rack gave me a bit more clerance for the exhaust
about 1-2 mm
#15 claysummers
claysummers
  • 3,738 posts
  • Name:Clay
Posted 30 March 2021 - 08:09 PM
Shaft profile has two opposing flats, like a D with two uprights.
#16 Dr Terry
Dr Terry
  • 3,350 posts
Posted 31 March 2021 - 07:01 AM
I've never looked at the square shaft being a "double D", now I understand.
I disagree about any difference in the head angle, the pinion & main shaft are the same parts with the same part numbers, how can the angle change ?
Dr Terry
#17 yel327
  • 13,864 posts
Posted 31 March 2021 - 07:14 AM
Different double D to what I pictured!
#18 claysummers
claysummers
  • 3,738 posts
  • Name:Clay
Posted 31 March 2021 - 07:32 AM
Theory vs practice. Funny old world.
early Holden nut
#19 hanra
  • 11,038 posts
Posted 22 April 2021 - 03:03 PM
Mate found something on r at to fit straight up. Problem solved hopefully.
