muncie into lx 4dr position
Posted 04 April 2021 - 12:02 PM
I'm also chasing hole position for shifter cut out.
I'm running a speco shifter.
Posted 04 April 2021 - 12:17 PM
Posted 04 April 2021 - 12:19 PM
Posted 04 April 2021 - 03:04 PM
One of these for $200 is probably a better thing anyway:
https://www.rodshop....-hol-lh-uc.html
Posted 04 April 2021 - 09:42 PM
What measurement do you need?
Posted 05 April 2021 - 05:01 AM
Posted 05 April 2021 - 11:58 PM
Posted 06 April 2021 - 05:15 AM
Posted 06 April 2021 - 09:26 PM
I have one of those fitted. I do remember there is a 10 mm thick steel plate shim between the central mount with the slots and the original holden transmission mount though. The bolts go through the slots, then the shim, then into the muncie extension housing.
Posted 07 April 2021 - 04:19 PM
Posted 07 April 2021 - 10:42 PM
what motors you running Lima and kirk
308, Muncie
Posted 07 April 2021 - 10:52 PM
And I'm an idiot - when I said "The bolts go through the slots, then the shim, then into the muncie extension housing." I meant that the bolts in the centre go through the shim to the std holden trans mount base, two outer bolts go through that mount into the muncie ears.
Posted 08 April 2021 - 12:58 AM
