M21 gearbox
13 replies to this topic
#1 _JJ21_
_JJ21_
Posted 21 April 2021 - 02:45 PM
Anyone seen an original V8 M21 box with painted letters "ZE" in yellow on the top?
Does it mean anything in particular?
I believe its later model box as has the switch on the selector input. Cluster is the 497 so definitely M21 ratio.
Edited by JJ21, 21 April 2021 - 02:46 PM.
#2 yel327
  • 13,081 posts
Posted 21 April 2021 - 03:13 PM
ZE is the broadcast sheet code for the box. It is to identify it in the VAP.
#3 Bigfella237
  • 4,371 posts
Posted 22 April 2021 - 09:53 AM
I have "ZD" recorded as a M20 from an '82 Commodore with an "L36" 4.2L blue motor.
And I have "ZF" listed as a M20 from an '82 Commodore 6 cylinder.
So I'd guess that "ZE" is probably a M21 from the same era 5.0L Commodore?
#4 _JJ21_
_JJ21_
Posted 22 April 2021 - 11:05 AM
Ok guys thanks for that...was curious to what it meant
#5 yel327
  • 13,081 posts
Posted 22 April 2021 - 01:12 PM
Or from a 4.2, if M21 was still optional behind 4.2L
#6 toranamech
toranamech
  • 111 posts
Posted 20 August 2021 - 10:43 AM
I have ZE from a VK 134 pack, L31 M21 optioned, so ZE must meant M21 in the V series Holdens
#7 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 21 August 2021 - 08:14 AM
They weren't in alphabetical order though, as ZL is a 1980 M20.
#8 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 21 August 2021 - 06:36 PM
Obviously the picking code also refers to the gear ratio aswell. I would say around early commodore aswell.
#9 Dr Terry
Dr Terry
  • 3,276 posts
Posted 23 August 2021 - 04:36 PM
Was that a 6 or a V8 gearbox ?
Dr Terry
#10 _JJ21_
_JJ21_
Posted 25 August 2021 - 11:05 AM
Hi Dr Terry,
Its a V8 gearbox. Has the M21 cluster numbers.
#11 Dr Terry
Dr Terry
  • 3,276 posts
Posted 25 August 2021 - 05:41 PM
Maybe the ZD V8 M20 was for Commodore & the ZE V8 M20 was for WB, i.e. different shifters.
Dr Terry
#12 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 31 August 2021 - 12:16 PM
Are you part of AHA Terry? There are a few of us compiling gearbox and engine numbers and I will send the list in once it is large enough.
#13 Dr Terry
Dr Terry
  • 3,276 posts
Posted 31 August 2021 - 05:55 PM
What or who is AHA ?
Dr Terry
#14 Shiney005
  • 9,034 posts
  • Car:Toyota Mirai
Posted 31 August 2021 - 06:10 PM
Attached File  Screenshot 2021-08-31 160935.png   198.67K   4 downloads
