LC Drum front end
9 replies to this topic
#1 champagne_metallic
champagne_metallic
  • 24 posts
  • Car:UC Torana
Posted 02 May 2021 - 06:30 PM
G'day
Got the opportunity to buy a mates LC of him, Its stock 161, 4 speed with Drums up front, all the LC/LJ's I've driven were disc fronts so i have no idea what these stop like
Eventually i would like to beef the 161 up, nothing crazy, just lumpy cam, head work to accommodate that, 350 Holley or 38 Weber and extractors.
Will the drums slow this thing down or should i upgrade?
Are there any kits that supply everything or do i have to chase down stub axles and what ever else?
#2 claysummers
claysummers
  • 3,310 posts
  • Name:Clay
Posted 02 May 2021 - 08:40 PM
S/H disc front ends are on Gumtree regularly for sensible money. Easy upgrade for a noticeable improvement.
early Holden nut
#3 Heath
  • 18,307 posts
Posted 03 May 2021 - 01:44 PM
It'll work, but you wouldn't regret a swap to discs if you enjoy driving.
#4 Bigfella237
  • 4,368 posts
Posted 03 May 2021 - 02:31 PM
Old-school-wise, drums actually stop better than discs because the shoes are self-energising (if the last guy installed them the right way around that is). That means that the rotation of the drum tends to pull the brake shoe in tighter against it as pressure is applied.
A disc brake requires more pressure to generate the same braking effect because they aren't self energising. That's why most of the old four-wheel-drum setups weren't vacuum boosted and most disc brake setups are. (If you've ever been towed in a four-wheel-disc equipped car then you'll know what happens when the booster vacuum runs out!)
However, disc brakes win out in every other area... better heat dissipation, simpler construction, less / easier maintenance, no adjustment needed, and better driver control over the braking effect generally.
#5 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 03 May 2021 - 04:13 PM
Castlemaine rod shop still do the disc conversion using those drum stubs if you want.
Otherwise easy straight swap to lc/j discs. Don't have to swap whole front end just stubs and brake gear.
Otherwise all the hoppers upgrades available just need any torana disc stubs lc to uc to do hoppers upgrades.
Changes to master cylinder and rear wheel cylinders from memory too.
#6 Ice
  • 15,118 posts
Posted 03 May 2021 - 04:24 PM
As above buy a set of stubs and just buy brand new rotors and pads
get a set hand set of callipers  recon
pretty much all you need
No idea which would be the cheapest option
#7 champagne_metallic
champagne_metallic
  • 24 posts
  • Car:UC Torana
Posted 03 May 2021 - 06:20 PM
Cheers all, appreciate the replies
#8 claysummers
claysummers
  • 3,310 posts
  • Name:Clay
Posted 25 May 2021 - 07:06 PM
Cheap LH front end for parts
https://www.gumtree....opytopasteboard
#9 Zook
Zook
  • 1,536 posts
Posted 25 May 2021 - 08:21 PM
Will that fit LC?
#10 claysummers
claysummers
  • 3,310 posts
  • Name:Clay
Posted 25 May 2021 - 08:39 PM
The stub axles discs and calipers will bolt up?
